sprocket(at)vx-aviation.c Guest
Posted: Tue Sep 14, 2010 6:27 am Post subject: Gear legs into engine mount |
<I've sent this email to John Harmon via his website, but there seems to be bugs with his online email utility>
I am attempting to insert my gear legs into the engine mount sockets.
I've cleaned out any primer in the socket and polished the socket with fine sandpaper to ease the fit, but I cannot get the gear leg all the way through the bottom of the socket. Visual inspection shows the inside of the socket somewhat rough (not polished).
What is the best technique here to make the legs fit? Both are the same-- they slide in for a couple of inches and then get jammed.
Ideas?
Vern Little
| | - The Matronics Rocket-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
lschneider39(at)cox.net Guest
Posted: Tue Sep 14, 2010 7:24 am Post subject: Gear legs into engine mount |
When ever I've had problem with the HR or RV fit I used a brake cylinder hone to polish the sockets some. It doesn't take much, be careful. Larry
Posted: Tue Sep 14, 2010 10:34 am Post subject: Gear legs into engine mount |
Thanks Larry, that's what I've been contemplating. I'm glad someone else has slain this dragon.
Vern
Sent: Tuesday, September 14, 2010 8:18 AM
To: rocket-list(at)matronics.com (rocket-list(at)matronics.com)
Subject: Re: Gear legs into engine mount
Posted: Tue Sep 14, 2010 6:03 pm Post subject: Gear legs into engine mount |
Update: Larry's technique worked fine, and the gear legs are now mounted. A really tight fit, but that's OK. I probably will have to drill them as a unit, because getting them off could be difficult.
Vern
Sent: Tuesday, September 14, 2010 11:30 AM
Vern
Posted: Tue Sep 14, 2010 6:54 pm Post subject: Gear legs into engine mount |
Great, just be sure that there is plenty of lube on them. Larry
