Throttle cables
JonSmith
PostPosted: Thu Sep 16, 2010 11:14 pm    Post subject: Throttle cables Reply with quote
Hi all, just a quick question. Should the stranded wire throttle cables be lubricated in any way or left dry? I'm in the process of fitting a Rotax (changing to a Rotax from an alternative engine type) and am about to bolt the throttle box and cables into the plane. Having fitted the cables into the throttle box they seem slightly stiff to move, but admittedly they are not yet connected to the carb throttle spring which should help them to open better.
I'm sure this has been covered a thousand times before but it's new to me so many thanks in advance...!
Jon
G-TERN
Classic Mono
europa(at)pstewart.f2s.co
PostPosted: Fri Sep 17, 2010 12:52 am    Post subject: Throttle cables Reply with quote
Jon
The cables are notoriously sticky and can give rise to difficulty with carb
balancing. Some have replaced with piano wire. On advice from Conrad Beal
(ConAir) we lubricated with ACF 50 and the cables run reasonably smoothly.
Don't rely on the carb springs to overcome much stickiness, they're not very
powerful.
Other useful advice from Conrad was make the throttle cable runs as smooth
an arc as possible, mirrored L & R and well secured so that the outer does
not move when actuating the throttle.
Paul
G-GIDY (awaiting permit to test!!)
Jon
G-TERN
Classic Mono
http://forums.matronics.com/viewtopic.php?p=312720#312720
gsessare(at)hotmail.com
PostPosted: Fri Sep 17, 2010 4:47 am    Post subject: Throttle cables Reply with quote
Hi Everybody,
I have almost ready to fly test a Europa monowheel with Jabiru 3300 and Aerocarb. the trottle systems is liske CESSNA but it did nto work well, to short from close to full open and not acuracy. any suggestion for other kind of system ? (may be throttle system by aerocarb)
regards from Argentina,
GUSTAVO
[quote] Date: Fri, 17 Sep 2010 09:45:36 +0100
Subject: Re: Throttle cables
Jon
jimpuglise(at)comcast.net
PostPosted: Fri Sep 17, 2010 8:56 am    Post subject: Throttle cables Reply with quote
Gustavo-
I also have a 3300 and build to throttle enclosure as specified in the Rotax documentation, then made a lever out of 1/8 aluminum, then used a Bowden cable. Your other alternative is that Vans has a setup that may be idea. I am not at home now and won't be for a month or so, but can send photos if you need them.
Jim Puglise
JonSmith
PostPosted: Sat Sep 18, 2010 1:51 am    Post subject: Re: Throttle cables Reply with quote
Thanks for the advice, much appreciated. Jon
G-TERN
Classic Mono
