CJ6 remote oil filter kits
Harv
PostPosted: Tue Sep 14, 2010 9:15 am    Post subject: CJ6 remote oil filter kits Reply with quote
Good morning
I'm thinking of fitting a remote oil filter to my my CJ-6a. Can anyone share details or recommend a kit they've fitted/used and experiences?
I was thinking maybe we could adapt a Mocal automotive system? (Not sure the filters are upto the pressures the Housai generates when starting from cold.)
The CJ dosent have a chip detector in stock configuration does it?
Best regards
Harv
keithmckinley
PostPosted: Tue Sep 14, 2010 2:14 pm    Post subject: Re: CJ6 remote oil filter kits Reply with quote
I'm VERY happy with my ADC kit. It's the spin on version and I have installed the chip detector. I like the large by-pass on the system since I live in the Northeast and have a lot of cold oil in the winter. The chip detector takes 3 seconds to remove should you need to check it.
barryhancock
PostPosted: Fri Sep 17, 2010 9:00 pm    Post subject: Re: CJ6 remote oil filter kits Reply with quote
We exclusively use the ADC filter system. It is the best performing filter on the market. We have also made several "kits" for customers including everything needed for installation. I am in the process of taking my spin on filter system in favor of the ADC. It's a bit more expensive than a spin on kit, but much better technology and more convenient.
Happy Flying,
Barry
Barry Hancock
Worldwide Warbirds, Inc.
www.worldwidewarbirds.com
gill.g(at)gpimail.com
PostPosted: Mon Sep 20, 2010 8:49 am    Post subject: CJ6 remote oil filter kits Reply with quote
Barry,
PurePower made a similar STC's spin filter with 100% flow through.
Cleanable element with magnets to remove iron particles. It has same micron
filtering as paper filters. Unit is pricey at $250 but screws on in place
of paper spin-on. I have used this unit for over a year.
Gill
barryhancock
PostPosted: Wed Sep 22, 2010 8:39 am    Post subject: Re: CJ6 remote oil filter kits Reply with quote
Gill,
That sounds like a good replacement for a paper filter. Does it have the "smart" technology of the ADC i.e. filter dirty light, chip light (option)? Particularly for the Housai which doesn't have a chip light on the motor like the M14P does, this is a very nice feature.
Barry
Barry Hancock
PostPosted: Wed Sep 22, 2010 12:42 pm    Post subject: CJ6 remote oil filter kits Reply with quote
Barry,
PurePower does not have a filter dirty indicator or a chip sensor. It is a
spin on filter replacement with built in magnets to remove ferric particles
which may get past the engine oil pump filter screens. This allows you to
see if you are making metal in your engine via excessive wear. The unit is
completely washable and reusable and has better flow characteristic than
spin on paper filters which by-pass significant oil flow as they begin to
load up. The M14P chip sensor is located ahead of the engine oil pump
filter screen and filter except for the pump screen are all located after
the pump. So, larger engine generated chips are trapped ahead of the oil
pump and shouldn't reach the filter.
I don't sell the PurePower filter, but it is a real nice unit and pricey.
Gill
barryhancock
PostPosted: Wed Sep 22, 2010 12:48 pm    Post subject: Re: CJ6 remote oil filter kits Reply with quote
Thanks, Gill. Sounds like a nice alternative....especially if you already have a spin on installation.
OH, and I've yet to see a really good product for an engine related accessory that isn't pricey. Wink
Barry Hancock
