				|  | Matronics Email Lists Web Forum Interface to the Matronics Email Lists
		| Author | Message |
		| loboloda(at)execulink.com Guest
				|  Posted: Mon Sep 20, 2010 10:50 am    Post subject: Low voltage |   |
				| Coming back to home base yesterday I noticed voltage was indicated at
11.5 rather than the usual 14.
 The ammeter was showing a slight discharge with the strobes on.
 Readings were not affected by engine RPM.
 I'd made a couple of stops along the way and had no trouble re-starting.
 I'm hoping that this is nothing more than an indication that my 6
 year old Odyssey battery has suffered a partial failure.
 As always suggestions on probable cause from those who have been
 there would be appreciated.
 Dave C-FBZI
 | |  |  | - The Matronics Europa-List Email Forum - |  |  |  | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:http://www.matronics.com/Navigator?Europa-List
		| Back to top |  |
		| paul.the.aviator(at)gmail Guest
				|  Posted: Mon Sep 20, 2010 11:50 am    Post subject: Low voltage |   |
				| Hi Dave,
 I would start with a discharge test on your battery.  Stores like Batteries Plus do this as a free service.
 Paul
		| Back to top |  |
		| Rocketman
				|  Posted: Mon Sep 20, 2010 2:12 pm    Post subject: Low voltage |   |
				| Dave,
 First thing I'd check is that big old 30 amp fuse, then go to the
 battery.  If that don't get it, check the regulator...
 Jeff - Baby Blue
 On 9/20/2010 1:50 PM, david miller wrote:
  	  | Quote: |  	  |
 I'm hoping that this is nothing more than an indication that my 6 year
 As always suggestions on probable cause from those who have been there
 Dave C-FBZI
 Checked by AVG - www.avg.com
		| Back to top |  |
		| rehn(at)rockisland.com Guest
				|  Posted: Mon Sep 20, 2010 2:37 pm    Post subject: Low voltage |   |
				| Dave
The Odyssey battery is likely what kept you going, I would suspect the regulator/rectifier. Mine went out and it sounds very similar to what you experienced. I also have the Odyssey it's like the energizer bunny! The battery would be the relative cheap fix so maybe?
 Jerry
 On Sep 20, 2010, at 11:50 AM, david miller <loboloda(at)execulink.com> wrote:
  	  | Quote: |  	  |
 Coming back to home base yesterday I noticed voltage was indicated at 11.5 rather than the usual 14.
 I'm hoping that this is nothing more than an indication that my 6 year old Odyssey battery has suffered a partial failure.
 As always suggestions on probable cause from those who have been there would be appreciated.
 Dave C-FBZI
		| Back to top |  |
		| frankm(at)clara.net Guest
				|  Posted: Wed Sep 22, 2010 1:59 am    Post subject: Low voltage |   |
				| Dave
 There is a piece in the Safety Spot in Septembers  Light Aviation about the same problem (though the answer may not be the  same).  Go to http://www.lightaircraftassociation.co.uk/2010/Magazine/2010/Sep/Safety.pdf and  look at the Himax article.  In that case the problem was neither the  battery nor the regulator/rectifier.
 Frank
		| Back to top |  |
				|  Posted: Wed Sep 22, 2010 12:42 pm    Post subject: Low voltage |   |
				| Thanks Frank,
So many causes of electrical problems !
 I charged my battery today, went to about 13V, but then as I held the voltmeter on the reading slowly
 began to decrease, working it's way down to the previously indicated 11.6V
 I'm presuming this is a battery in need of replacement.
 Dave
 On 22-Sep-10, at 5:27 AM, Frank Mycroft wrote:
 [quote]  Dave
 Frank
 [b] 	  | Quote: |  	  | href="http://www.matronics.com/Navigator?Europa-List">http://www.matronics.com/Navigator?Europa-List
		| Back to top |  |
 | You cannot post new topics in this forum You cannot reply to topics in this forum
