philperry9(at)gmail.com Guest
Posted: Thu Sep 23, 2010 6:37 am Post subject: Andair Fuel Assembly |
Hi Everyone,
Are any of you using the Andair Fuel Filter and Pump? If so, do you have photos of your installation?
I'll post some photos or a video of mine so you can see how I did it. But I'd like to compare my installation to others and confirm that I haven't done anything stupid.
I'm also curious to know which model number of pump and filter you're using. I have their filter/pump combo for 3/8" lines (which are what we use in the RV-10), but their site suggest this pump combo is for IO360's and such. The folks from Andair said this was the right pump at Oshkosh, but I'd like to make sure.
Andair sells a pump marketed for the IO540, but it has 1/2" lines.
So before I do something really stupid, I'd like to bounce this off a few other Andair RV-10 drivers/builders to see what they're using and doing inside the tunnel.
Phil
