| Fergus Kyle
				|  Posted: Thu Sep 30, 2010 6:20 pm    Post subject: Dynon EFIS D100, ATTN Bud Yerly |   |
				| Bud,
Once again your timely reply is most appreciated. I know that several correspondents on net have mentioned the value of your attention to the list. Thank you.
 I suspected that Dynon might  not have produced the ideal device and that there were many more for research, but must ‘fess up’ that I had already installed the EMS-D10A unit in attempting to overcome the nose-heavy result of 914 plus CS prop (Woodcomp). The assumption was that several pounds ahead of CoG could be saved by avoiding vacuum-driven dials and their hardware.
 For that reason I think I’ll have to go with the D100 because;
 (a)     there’s a saving in weight from my homemade EFIS (mini-Mac);
 (b)     they have fashioned an “exchange” link between the two (DSAB);
 (c)     their wiring harness seemed a lot simpler than my alternative;
 (d)     the space available won’t accept the D10 but will the D100;
 (e)     I can easily incorporate a cooling fan overhead; and
 (f)     I can get the D100 from a nearby AS outlet (simplified tax/import duty).
[quote][b]I was heartened to see you said that installation was relatively easy. I appreciate that these reasons may be less than ‘engineering’ logic, but unless there is outstanding clamour otherwise, will have to go with it.
 Again, much obliged.
 Ferg
