Belleville Washer
Sigmo(at)aol.com
PostPosted: Mon May 01, 2006 4:08 pm    Post subject: Belleville Washer Reply with quote
I am mounting a GT prop on a Jabiru 3300 engine. The diagram calls for six
AN4-43A bolts and twelve PH11773N belleville washers.
I have made searches on every search engine I can find and can not find the
belleville washers with that part number.
Can anyone tell me where I can get these using that part number or get the
spech's needed to get them from a Belleville supplier?
Mike Sigman
N7092N
Andy Silvester
PostPosted: Wed May 31, 2006 5:26 pm    Post subject: Re: Belleville Washer Reply with quote
Jabiru specify using Bellville washers for mounting Jabiru propellers, because the wood they use is softer (relatively) than is used by other prop manufacturers. The washers are made of spring steel and 'dished' so that when torqued correctly, they exert some axial load and therefore retain tension to accommodate the wood moving with changes in humidity etc. A stack of Bellvilles allows a greater tolerance of movement.
In the case of the GT propeller, which uses a denser wood, you don't need them unless specified by GT. The same goes for all other prop. manufacturers; use their specified method of mounting. We stock the Bellville washers for use on Jabiru props.
Andy Silvester
info(at)usjabiru.com
PostPosted: Thu Jun 01, 2006 6:17 am    Post subject: Belleville Washer Reply with quote
Belleville washers can be found at www.mcmaster.com part number 9712K68
Pete Krotje
Jabiru USA Sport Aircraft, LLC
jetboy
PostPosted: Tue Jul 25, 2006 1:24 am    Post subject: Re: Belleville Washer Reply with quote
Please advise where the installation diagram is for those 12 washers? are they stacked together or opposing?
I have been finding low torque on the bolts every 5 hrs or so and would have fitted the washers had it been known they were called for. I looked at all the downloads and my manuals and CD theres no reference there so this must have been introduced since my engine new 2 yrs ago.
Ralph - CH701 / 2200a
tonyplane(at)bellsouth.ne
PostPosted: Wed Jul 26, 2006 5:35 am    Post subject: Belleville Washer Reply with quote
The washer are installed "toe to toe" i.e. ( ), under the nuts and are shown
on Jabiru dwg C009013-1. Go to Jabiru USA for their Zenith Firewall Forward
and pull up "Fit prop and spinner assy" found at
http://www.usjabiru.com/Zenith%20FWF%20Images/79.%20Fit%20Prop%20&%20Spinner%20assy.PDF.
Note: Recommend you use the torque values recommended by your prop
manufacturer vice those shown for Jab. It is my understanding that the
wood used in Australian Jab props is a little softer and therefore more
"crushable" than woods used by prop manufactures such as Sensenich.
Tony Graziano
Zodiac 601XL; N493TG - 120 hrs.
> Time: 02:27:44 AM PST US
Subject: Re: Belleville Washer
they
have
all the
have
http://forums.matronics.com/viewtopic.php?p=49697#49697
