		cjhukill(at)cox.net Guest
				 Posted: Mon Oct 11, 2010 7:48 am    Post subject: reinforcing door hinges |
				Timely question of reinforcing the door hinges, as  that is what I'm doing right now. I feel the standard attachment method is  flawed, at least for me. The reason is, I have always taxied airplanes with the  door ajar for extra ventilation, especially here in Las Vegas. When I tried to  open the door while taxing the Vans RV10 during a demonstration ride many years  ago, I was chastised for it because the demo pilot warned me the doors are "weak  link". A forward hinged door, like  on a Cessna, will take the prop-blast  in stride, and the blast will try to move the door in the direction it  wants to go. A top hinged door when hit with a prop-blast or gust of wind, will  try to open the door, as the in-flight RV10 door failures would indicate.(none  of unlatched doors tried to slam shut, that I've heard of). I have a secure  strap attachment nutplate, reinforced with an aluminum plate, glassed inside the  door halves, to allow me a nylon strap to hang onto while the door is partially  open, during taxi.The hinges are being reinforced with an aluminum plate on the  outside of the doors, thru which the countersunk screws will pass. The plate is  approximately the same size as the indentations (pockets) in the inside of  the door, where the hinges mounts. The inside plate, also the same size as the  tapered down portion of the pocket, has nutplates mounted for the screws.  The hinge is embedded in epoxy/cabosil, that was set with mold release, so the  hinge can slide in and out of this channel, for removal. The inside plate  is then covered with carbon fiber, up the sides of the hinge pockets,and epoxied  on. The remaining depth of the pockets are then filled with micro, so the  pockets are now flush with the doors. The result is a significantly stronger  hinge attachment, that should survive my desire to abuse my doors while taxing.  Who knows, it may be strong enough to survive an in-flight opening?
  Chris Hukill
		glastar(at)gmx.net Guest
				 Posted: Mon Oct 11, 2010 10:57 am    Post subject: reinforcing door hinges |
				Chris,
 any pictures available?
 Werner
 On 11.10.2010 17:44, Chris Hukill wrote:
  Chris Hukill
		daveward(at)airward.com Guest
				 Posted: Wed Oct 13, 2010 4:40 pm    Post subject: reinforcing door hinges |
				We at www.airward.com have developed a door hinge  reinforcing kit similar to what you described.  Take a look.  Dave  Ward
