graeme bird
Posted: Thu Oct 21, 2010 12:29 am Post subject: Transponder antenna |
I am considering putting the transponder antenna in the middle on a 1ft square copper clad single sided PCB on the floor behind the baggage so it doesnt poke through. Any other suggestions from the wise ones?
_________________ Graeme Bird
kit4 (Wagstaff) TBD
Kit 1 G-UMPY - Mono Classic/XS 912S, Woodcomp G(@)gdbmk.co.uk |
milneab(at)btinternet.com Guest
Posted: Thu Oct 21, 2010 2:35 am Post subject: Transponder antenna |
That location and an aluminium (cooking) foil ground plane stuck to the
fuselage shell works on my aircraft with a shark's fin aerial.
When you have it flying just remember to be wise and not to crawl under the
rear fuselage and catch the aerial!
Alasdair Milne G CEYK
Ivor Phillips
Posted: Thu Oct 21, 2010 2:51 am Post subject: Transponder antenna |
Hi Graeme
I use a Bob Archer Transponder Antenna (fully contained internal antenna)
in the rear fuselage just in front of the rear Push rod containment bulkhead
It has worked well these last couple of tears with no problems of reception or transmission,
Ivor
On 21 October 2010 09:29, graeme bird <graeme(at)gdbmk.co.uk (graeme(at)gdbmk.co.uk)> wrote:
[quote]--> Europa-List message posted by: "graeme bird" <graeme(at)gdbmk.co.uk (graeme(at)gdbmk.co.uk)>
Graeme Bird
http://forums.matronics.com/viewtopic.php?p=316545#316545
Subscription,
www.matronics.com/Navigator?Europa-List" target="_blank">http://www.matronics.com/Navigator?Europa-List
ronics.com/" target="_blank">http://forums.matronics.com
Matt Dralle, List Admin.
wdaniell(at)etb.net.co Guest
Posted: Thu Oct 21, 2010 4:46 am Post subject: Transponder antenna |
Ivor
I bought one of these and a comm antenna but have yet to install it ....how are yours mounted?
Will
On 21-Oct-10 05:49, PHILLIPS I wrote: [quote] Hi Graeme
Ivor
