Slow day --- and cracks in the horizontal.
gilalex(at)earthlink.net
PostPosted: Mon May 01, 2006 10:40 pm    Post subject: Slow day --- and cracks in the horizontal. Reply with quote
I always use the Black RTV 732. It looks a lot better than the orange
stuff.
I guess it's not too hot there, and the black would definitely look
better. I'll try that this week.
I've seen as much as a 30 degree drop when the cylinder baffle strap is cut
back on cyls #3 and #4. The larger exit ramps help also.
It definitely helped.. but I can't read numbers on the GEM 602.... bummer,
I like numbers...
I did discover keeping your 1800 rpm run-up short helped... if yoou start
the take-off with cooler cylinders, they stay cooler much longer.. hot
cylinders take a long while to cool, even when you reach cruise....and the
new Horizon digital tach made the mag checks easier and quicker...
OK, I'm doing an annual on a plane that has cracks in the vertical supports
and the horizontal stiffener on the horizontal. Gil, I think this one is
cracked like yours. Do you know if your plane ever had damage to the
horizontal?
This one has had the leading edge of the horizonatl replaced.
Yes... mine had hangar rash on the horizontal, a dent was on the left
leading edge as far out as possible, with some attempt at straightening.
Also some rash on the elevators trailing edges.
If you go for the inertia theory (wing stops, tail doesn't), there was also
a fairly large dent on the wing leading edge on the left just short of the tip.
I've hired a DER to help engineer a better fix than just replacing the same
parts. If it works, I'm going to do an STC for it.
That would be good.... I'd like to find out if any repaired ones get
buckled again, then we might find out what actually does it...
There . . . . . is that a good story?
Pretty good....
or, how about
a McCauley prop for a Cheetah that has been cut down to 72 inches and pitched
to 63? New LyCon O320, ported and polished, turns 2850 at 7500 feet.
Trues at 134 knots at 7500 feet at 2700 rpm.
or, how about
I averaged 147 knots flying to Lancaster in my Tiger.
or, how about
I'm doing an STC for my larger cooling exit ramps.
or, how about
have you seen the one piece instrument panel I did for a Tiger about 6 years
ago? Well, I'm going to do another one. This one will be simialr but
'better' in my opinion.
or, how about
I've eliminated all of the interior plastic except for the canopy window
trim, the rear window trim and the forward console covers. That
includes the
center plastic piece on the canopy and the top console cover in the
front. The
top console cover is made of Carbon fiber with a cup holder!
Hey, somewhere for your beer can!!
Any more details on the center canopy trim.. mine's getting shot... I
think the last interior work put in foam that was too firm...
gil in tucson
Gary
ddmcknight(at)alltel.net
PostPosted: Tue May 02, 2006 4:53 pm    Post subject: Slow day --- and cracks in the horizontal. Reply with quote
Sealing the oil cooler to baffle sounds like a good idea, how much should
the cylinder baffle straps be trimmed back??
Dave
Tiger N880DM
