Slow day --- and cracks in the   horizonta
GrummanDude
PostPosted: Mon May 01, 2006 11:10 pm    Post subject: Slow day --- and cracks in the   horizonta Reply with quote
In a message dated 5/1/06 11:41:07 PM, gilalex(at)earthlink.net writes:
>I always use the Black RTV 732.=A0=A0 It looks a lot better than the oran=
ge
>stuff.
=20
I guess it's not too hot there, and the black would definitely look
better.=A0 I'll try that this week.
=20
There is no where on the whole plane that requires the red stuff.
Gary
AuCountry Aviation
Home of Team Grumman
GrummanDude
PostPosted: Mon May 01, 2006 11:13 pm    Post subject: Slow day --- and cracks in the   horizonta Reply with quote
Hey, somewhere for your beer can!!
=20
Any more details on the center canopy trim.. mine's getting shot...=A0 I
think the last interior work put in foam that was too firm...
=20
I had the canopy headliner covered from side to side. I filled the low=20
spots in the U-channel with foam and then put 1/8 inch high density foam acr=
oss=20
the whole thing and then covered it with material. If you do this, keep th=
e=20
canopy latch cover handy to figure out how to cover around where it goes. =20=
I've=20
done 6 planes like this so far.
Gary
Gary
AuCountry Aviation
GrummanDude
PostPosted: Tue May 02, 2006 11:55 pm    Post subject: Slow day --- and cracks in the   horizonta Reply with quote
In a message dated 5/2/06 5:54:27 PM, ddmcknight(at)alltel.net writes:
Sealing the oil cooler to baffle sounds like a good idea, how much should
the cylinder baffle straps be trimmed back??
Trim the straps back about 1 to 1 1/4 inches. Cut off the corner (about
half) on a 45 degree (on the outside). Then, turn down the end like a lip. Tie
the baffles up tight. All of them. The straps on #1 and #2 do not need to
be cut back.
Gary
AuCountry Aviation
