wingsdown(at)comcast.net Guest
Posted: Tue May 02, 2006 11:09 am Post subject: KIt Fox and other items for sale |
Model 5 Kitfox and other parts Remaining for sale:
Custom air oil separators as seen on sportflight pic post $150.00 each
CAP 140 complete hub assembly for NSI redrive, may fit others, no blades
$1,500 OBO
E.I digital EGT instrument, no probe $180 each or both for $300.00
Hand held radio Yaesu VXA-200. This was there top of the line model and
should be compared to same now, has altitude, density altitude, pressure
alt. Temp, VOR heading plus extra Nmhi battery and programming software
and cable, list was over $600.00 sell for $350.00
COM/nav antenna model VHF5-1 by AAE thin flat composite style list $125
sell for $85.00
E.I. Electronics International Digital Volt/Amp gage with over and under
voltage indication internal shunt model VA-1A list $285 sell for %200.00
Carb ice gage with sending probe $45.00
Intercom by PS Engineering model PM1000II with digital cockpit record
option $300.00
Electric clock model MD-90 $60.00
Turtle deck with smoke grey lexan, has scratch in glass 150.00 if you do
a pick up I have material for replacement.
Electric servo/ jack screw assembly $500.00 OBO
Wheel pant left side only painted ready to mount or repaint $50.00
Rudder $300.00
Elevator $225.00
VDO gages:
2 1/8 tack , water temp,oil pressure, boost, large RPM 3 1/8 maybe 1/4,
EGT make offer.
Cargo bay bag with aluminum custom fit bottom, no sagging.
Left long wing, moderate damage pick up only, $1,500.00
Right long wing major tip damage , $750.00
Lift struts, pair, faired $600.00 pick up only
Horizontal Stabilator faired strut braces pair $100.00
Trim assist attached to mixer $80.00
Low level fuel indicator, SS PN 10116.000 with factory drawing and
install instruction $125.00
Custom super trapp exhaust system. Will require the welding of a 3 bolt
flange to exhaust down pipe. $300.00 Pics on request.
EA-81 turbo engine parts, blocks, cranks, rods, push rods, heads, cams,
open price to be set, accepting offers.
NSI alternator pulley New $60.00
Stock small NSI oil cooler $50.00
NSI redrive new set of gears. I believe these are 2.34:1 set but can
check and verfy $75.00
NSI redrive gear puller $45.00
SS flight controls all factory parts available in excellent condition.
Strut end farings. These go at the top of the strus for less drag.
$60.00 for the complete set never installed.
Carbon monoxide by coguardian. Plugs into lighter socket audible plus
digital level indicator. They have a web site. $99.00
I will try to keep this up to date and delete and add as necessary.
Once I receive a commitment to purchase I will remove the item from the
list.
Thanks so much
Rick
darinh
Posted: Wed May 03, 2006 8:54 am Post subject: Re: KIt Fox and other items for sale |
Rick,
Do you know if the cargo bag will fit in the Series 7? If so, I may be interested and how much do you want for it? Any pics?
Darin
Posted: Wed May 03, 2006 5:32 pm Post subject: KIt Fox and other items for sale |
Maybe someone else on the list might know. I think it will, but I don't
want you disappointed. Asking 95.00 with aluminum bottom.
darinh
Posted: Wed May 03, 2006 6:04 pm Post subject: Re: KIt Fox and other items for sale |
Rick,
Thanks, I will check into it and get back to you.
