a stall between 2 fools
vince(at)devonwindmills.c
PostPosted: Mon May 08, 2006 12:48 am    Post subject: a stall between 2 fools Reply with quote
.Pat,
I didnt reply to this because of spam prolems but now I have
read it again.I wasnt sure if you were pulling my and everyones leg.
But now I believe you may have at least one idea at variance
with my understanding.Particularlynabout the demise of the Flea.The list of
planes I gave you were all famously pitch unstable to some extent., and
would be able to runaway into a dive as the centre of pressure moved back so
far that the remaining pitch up authority of the controls was insufficient
the flea woud have its front wing cof p go to the trailing edge if reduced
to about zero angle of attack, speed would increase and the fixed lifting
tail would increase lift with its own c of p moving back. From that
condition without being able to exert downforce at the back a tuck/dive
would continue which was not recoverable.[The deepstallers were the Trident
and Bac111-but they were fixed]
. Modern Fleas were fixed, have moving control of part or all
the rear surface.
Hang gliders had a similar problem and without some ability to
counter rearward movement of the main centre of pressure will tuck
/overspeed.
ALL classic aircraft have to provide a sufficient downforce on
the tail to balance the couple derived from all lift forces against all
downward g forces{lets forget about the pitching couple of thrust against
drag] If cog g is allowed to move back the tail downforce can be reduced for
less drag but then pitch instability sets in and there is a limit you cannot
safely exceed.I have flown aircraft which due to bad loading were beyond the
authorised aft c of g anI can assure you they were very unpleasant That is
why there is so much attention to the cof g position on the weight and
balance part of permit to fly renewals {There are exceptions which rely on
computer control programming, such as the euro fighter and also Boeing and
Lockheed prototypes}
So yes there is in normal flight a down load on the tail and if the
download rquired is high enough the elevator can stall.Typically the use of
flaps brings main cof p back, requiring increased up elevator and a retrim.
Remember when you have trimmed to fly normal flight with stick
neutral that does`nt mean there is no down force on the tail
.On our microlights without benefit of so much design expertise
and wind tunnel work, there may not be enough elevator authority to complete
a landing flare, so a good fix is the turbulators under the tailplane
Vince Hallam
please phone rather than email
07941 313141
01803 316191
www.devonwindmills.co.uk
pj.ladd(at)btinternet.com
PostPosted: Mon May 08, 2006 12:53 pm    Post subject: a stall between 2 fools Reply with quote
Particularly about the demise of the Flea>>
Hi Vince,
Sorry. Just sloppiness on my part. I should not have just lumped
uncontrollably diving into the ground in the same category as `deep stall`.
Incidentally, I saw one of the original Fleas on display at our largest
ultralight show last week. A ferocious piece of work. I don`t think anyone
who actually knew much about planes would willingly trust themselves in it.
Of course most of the people who were building them back in the 30`s DID NOT
know anything about flying and the promise of easy construction, cheap
flying blinded them to the fact that it was dangerous.
Even the new models don`t inspire a great deal of confidence but they are
very manouverable. I have seen film of a Flea get together in France .
People turning up towing the Flea on its own wheels behind their cars,
putting the thing together and flying. There did seem to be a lot of
taxying and not much actual flying.
Cheers
Pat
Version: 7.1.392 / Virus Database: 268.5.5/333 - Release Date: 05/05/2006
rsanoa
PostPosted: Mon May 08, 2006 2:28 pm    Post subject: a stall between 2 fools Reply with quote
Tons of Fleas flying. The new design flys perfectly safely. As with all ultralights, the problem remains, a suitable light weight and reliable engine. Type in Flying Fleas into Google and find plenty of links for information.
Do not archive.
UltraStar, Tenn.
Hi Vince,
Cheers
Pat
New Yahoo! Messenger with Voice. Call regular phones from your PC and save big.
Ray S.Anderson
PostPosted: Tue May 09, 2006 4:37 am    Post subject: a stall between 2 fools Reply with quote
The new design flys perfectly safely>>
Hi Ray,
they seem to be OK and a couple have arrived across the Channel from France
for our major ultralight show. Very, very draggy. I wouldn`t buy one.
I still love the subject title>
Pat
