john.greenhalgh1(at)sky.c Guest
Posted: Thu Oct 21, 2010 1:05 pm Post subject: Brakes Bleeding |
Hi,
Is there anyone who can advise on bleeding the brakes on my europa.
The method stated say just use a sqeegy bottle and pump from each
wheel.
I t would appear that I cannot feed any fluid through the system.
Any advise would be appreciated.
Regards John
dpark748(at)hotmail.co.uk Guest
Posted: Thu Oct 21, 2010 1:32 pm Post subject: Brakes Bleeding |
John, just filled my system on the MONO loosen the bleed nipple and connected an oil can with a pump lever with a small plastic tube and pumped oil in to the system.
Dave LDVO
> Date: Thu, 21 Oct 2010 22:02:37 +0100
[quote] Subject: Europa-List: Brakes Bleeding
--> Europa-List message posted by: John Greenhalgh <john.greenhalgh1(at)sky.com>
Hi,
wheel.
Regards John>
neveyre(at)aol.co.uk Guest
Posted: Thu Oct 21, 2010 9:47 pm Post subject: Brakes Bleeding |
Hi John,
Get a large syringe from a Vet', use with a short piece of model glow fuel line on the nipple of the caliper and shoot the fluid up hill.
Nev.
Posted: Fri Oct 22, 2010 5:58 am Post subject: Brakes Bleeding |
On 10/21/2010 11:02 PM, John Greenhalgh wrote:
| Quote: | Is there anyone who can advise on bleeding the brakes on my europa.
If you have a tri-gear, and the other master cylinder brand than Matco
(forgot the name but I think it started with a "J"), toss it away and
install Matco brake cylinders instead. I spent a whole frustrating
weekend to try to bleed that other brand, but those things are just
horrible and badly manufactured. In fact, if you would manage to bleed
them properly after all, you will most likely end up replacing them by
Matco's anyway, as these things usually develop problems (leakage,
jamming) after a short time of usage.
After I installed the Matco's, bleeding was a non-event that took a few
minutes. In the 100 hours I have been flying with them during the last
half year, I had no problems with them. Feel and braking capacity is
perfect.
Succes,
Frans
