frank3phyl(at)comcast.net Guest
Posted: Fri Oct 22, 2010 5:55 am Post subject: EGT Problem |
I have a ROTAX 912S with GRT EIS model 2000. #3 EGT reading suddenly became erratic--going from very low reading to normal with all sorts of readings in between within a second or two. Now I'm getting a steady 25 degree C reading. Fastening to exhaust is secure & haven't checked other connections, yet. Question: what happens when the EGT thermocouple goes bad? Is this likely my problem or more likely a loose connection in wiring? Other three EGT readings are good.
Frank
longg(at)pjm.com Guest
Posted: Fri Oct 22, 2010 7:01 am Post subject: EGT Problem |
Frank,
This happened to me recently when I was in there fixing something unrelated and simply bent the wire back. I got all kinds of wacky readings. A simple disturbance like bending the wire can affect the reading dramatically. They don’t go bad that easily.
Glenn E. Long
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of frank3phyl(at)comcast.net
Sent: Friday, October 22, 2010 9:51 AM
Subject: AeroElectric-List: EGT Problem
Frank
| Quote: | | _-============================================================_-=Â Â Â Â Â Â Â Â Â - The AeroElectric-List Email Forum -_-= Use the Matronics List Features Navigator to browse_-= the many List utilities such as List Un/Subscription,_-= Archive Search & Download, 7-Day Browse, Chat, FAQ,_-= Photoshare, and much much more:_-=_-=Â Â --> http://www.matronics.com/Navigator?AeroElectric-List | 0123456789 | Quote: | | _-============================================================ | 0 | Quote: | | _-============================================================ | 1 | Quote: | | _-============================================================ | 2 | Quote: | | _-============================================================ | 3
BobsV35B(at)aol.com Guest
Posted: Fri Oct 22, 2010 7:24 am Post subject: EGT Problem |
Good Morning Frank and Glenn,
The most common problem with probe reading is because the wires to the probe are loose. You are supposed to place the toothed washer between the two ring terminals, not under the nut or screw, and it must be tightened thoroughly.
I would check that fastener for proper application and maybe install a new washer just in case.
The current flowing through that connection is very small and it needs to be clean and tight.
Happy Skies,
Old Bob
In a message dated 10/22/2010 10:02:36 A.M. Central Daylight Time, longg(at)pjm.com writes:
Frank,
Glenn E. Long
Subject: EGT Problem
Frank
- List Contribution Web Site -[/b]Thank you for your generous support!-Matt Dralle, List Admin. --> http://www.matronics.com/contribution[/b] | 01
[/quote]
