rtitsworth
Posted: Thu Oct 21, 2010 6:07 pm Post subject: Voltage Regulator Sense Wire Location |
Bob,
I'm building a 28v Z-14 type dual-battery/dual-bus system with the voltage
regulators on the inside of the firewall and both 24v batteries in the tail
(for weight/balance considerations).
I have 1 LR3C regulator paired with the std Kelly alternator and 1 LS1A
regulator paired with a SD-20 alternator.
I'm curious, where is the "ideal" location to connect the voltage sense wire
(regulator terminal #3) to:
a) Routed back to the battery contactors (i.e. near the batteries)
b) Anywhere on the power bus(es) near the voltage regulators (i.e. inside of
the firewall power bus stud)
c) Through the firewall to the alternator
d) Doesn't really matter (option B for convenience)
I'm assuming I should also set-up/adjust the regulator/alternator output by
measuring the voltage back by the batteries.
Rick
Posted: Fri Oct 22, 2010 7:25 am Post subject: Voltage Regulator Sense Wire Location |
At 09:03 PM 10/21/2010, you wrote:
<rtitsworth2(at)mindspring.com>
Bob,
What kind of airplane are you building?
The prefered v-sense points are as shown on Z-14
. . . or per manufacturer's instructions.
No, the voltage regulator "knows" what the voltage
is at its sense terminal. It can make no accurate
assumptions otherwise. Having said that, voltage drops
are, by system configuration, tolerably insignificant.
Fitting the LR/LS series regulators with sense leads
isolated from the field current supply lead went to
the idea of making voltage drops elsewhere still more
insignificant.
Recommend you wire per suggested diagrams and adjust
regulator as necessary to achieve 28.5 to 29.2 volts
at the bus.
rtitsworth
Posted: Fri Oct 22, 2010 8:15 am Post subject: Voltage Regulator Sense Wire Location |
Bob Thanks,
Answers FYI...
Lancair ES-Turbo (in the Detroit area)
B&C circuit diagram shows sense wire(s) going to the breaker panel/bus, which I can easily do, but that's 14 feet from the batteries via #2AWG (apparently not a big deal).
Rick
Posted: Fri Oct 22, 2010 1:50 pm Post subject: Voltage Regulator Sense Wire Location |
B&C circuit diagram shows sense wire(s) going to the breaker panel/bus, which I can easily do, but that's 14 feet from the batteries via #2AWG (apparently not a big deal). |
Correct
Bob . . . [quote][b]
