mlariv2421(at)yahoo.ca Guest
Posted: Tue May 02, 2006 4:46 am Post subject: Full-Lotus Floats with Nitrogen Gas |
Hi to all
Does anyone have any experience (or know someone who
has) with these floats being filled with nitrogen gas
instead of compressed air.
Removing the bladders every season to drain the
condensation water can be a pain in the neck in the
long run.
Mich
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
bnn(at)nethere.com Guest
Posted: Tue May 02, 2006 7:39 am Post subject: Full-Lotus Floats with Nitrogen Gas |
At 05:44 AM 5/2/2006, you wrote:
| Quote: | Removing the bladders every season to drain the
long run.
It might be easier to use a paint spray setup when you fill. My compressor
has a air dryer that would probably remove enough moisture to prevent
condensation.
Guy
clemwehner(at)sbcglobal.n Guest
Posted: Tue May 02, 2006 8:47 am Post subject: Full-Lotus Floats with Nitrogen Gas |
I once needed really dry air from my paint compressor. I ran 50 feet of
air hose coiled up in an ice chest filled with ice, then to a painting
air dryer (water separator), then to my hose going to the sprayer. The
cold air hose really forced out all the moisture so when it got to the
water separator it collected a lot of water that I probably would not
have gotten out without cooling the air coming out of the compressor. It
worked great.
Clem
Lawton, OK
KFIV-912
long run.
compressor
condensation.
Guy
Richard Rabbers
Joined: 09 Jan 2006 Posts: 114 Location: Benton Harbor, MI - USA
Posted: Wed May 03, 2006 3:38 pm Post subject: Re: Full-Lotus Floats with Nitrogen Gas |
| Quote: | | condensation water |
I believe, though am not certain, that the bladder material is urethane.
Moisure vapor tranmission through this film occurs over time.
Dry air is a good starting point.
_________________ Richard in SW Michigan
Model 1 / 618 - full-lotus floats (restoration) |
