Rotor gap
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Stratus-List
tshank(at)core.com
PostPosted: Tue May 02, 2006 4:24 pm    Post subject: Rotor gap Reply with quote
I'm trying to find out the the proper gap is between the magnetic pickup
in the distributor the the rotor that triggers it on a Stratus Subaru,
0.020 won't work and 0.011 will, but what is the spec on this?
Tim Shankland
- The Matronics Stratus-List Email Forum -
http://www.matronics.com/Navigator?Stratus-List
larry(at)macsmachine.com
PostPosted: Tue May 02, 2006 4:51 pm    Post subject: Rotor gap Reply with quote
Tim,
The factory gap setting is .008 to .016. A smaller gap will result in a
spark at a lower rpm than with the larger gap.
Play in the distributor shaft should not be allowed to take the gap out
of the tolerance range.
Taken from the instruction manual by Paul Messenger.
Larry McFarland - 601HDS at www.macsmachine.com
Tim Shankland
tshank(at)core.com
PostPosted: Wed May 03, 2006 4:42 pm    Post subject: Rotor gap Reply with quote
Thanks, that's what I was looking for.
Tim
LarryMcFarland wrote:
Tim,
>Tim Shankland
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Stratus-List All times are GMT - 8 Hours
