dlm34077
Posted: Fri Nov 05, 2010 7:42 pm Post subject: Tutrak PIREP |
In September I posted some pictures. Tim noticed that my VSGV AP was showing a constant need for trim. I had not considered that the constant running might be a problem. I bought the TT Auto pitch trim module and temporarily wired it in. As it turned out the module only ran the servo one way. After checking voltages it was determined that the servo needed recalibration, especially the trim sense function. I removed that servo and sent to TT; they returned promptly and reinstalled today. When I removed the TT servo I told the AP pitch=no and assumed that I would need to turn it on when I replaced the servo. Apparently not. The servo and pitch trim unit somehow reset the pitch=no to pitch=yes without my intervention. I test the new unit tomorrow so will see how much difference.
