dlm34077
Posted: Tue Nov 02, 2010 10:58 am Post subject: quadrant throttle and mixture cable lengths |
The original throttle and mixture cable lengths are reported to be 45.5 and 49.5 inches. For my installation they are only adequate by routing between the motor mount and engine. I routinely replace the external protective covering of propylene tubing. I am thinking that if I replace these cables with a longer version i can eliminate an item of routine maintenance. What cable lengths are others using for the quadrant. The prop cable supplied seem fine.
Posted: Tue Nov 02, 2010 8:51 pm Post subject: quadrant throttle and mixture cable lengths |
Cable lengths:
http://tinyurl.com/23m9ejx
Dave Saylor
AirCrafters
140 Aviation Way
Watsonville, CA 95076
831-722-9141 Shop
831-750-0284 Cell
On Tue, Nov 2, 2010 at 11:55 AM, DLM <dlm34077(at)cox.net> wrote:
rleffler
Posted: Wed Nov 03, 2010 1:36 am Post subject: quadrant throttle and mixture cable lengths |
Dave,
I would be interested in the vendor contact info that you got these for under $200 for all. The best I've found is about $150 each.
bob
_________________ Bob Leffler
N410BL - Phase I
Posted: Wed Nov 03, 2010 6:59 am Post subject: quadrant throttle and mixture cable lengths |
The vendor is California Push-Pull in Chico, CA. Talk to Frank.
http://www.push-pull.com/
I'm out of the shop today but I'll get you the specific PNs when I get
back. Frank might have them on file. It's the black-sheathed, high
temp cable.
Dave Saylor
AirCrafters
140 Aviation Way
831-722-9141 Shop
831-750-0284 Cell
On Wed, Nov 3, 2010 at 2:31 AM, Bob Leffler <rv(at)thelefflers.com> wrote:
Dave,
bob
