Wheel Fairing Mount maintenance issue - a must-read for flyi
Tim Olson
PostPosted: Sun Nov 07, 2010 6:33 pm    Post subject: Wheel Fairing Mount maintenance issue - a must-read for flyi Reply with quote
This isn't a completely new issue....I think maybe Bill
DeRouchey reported the same problem a couple years back.
But, I can guarantee that this is going to be an issue that
will eventually affect most every RV-10 built to date, unless
they did something to fix it already.
See my write-up here:
http://www.myrv10.com/N104CD/maintenance/20101107/index.html
Just like the original axle extensions, and nosewheel axle
spacers, this is going to be one of those problems that will
almost definitely affect you....but luckily the problems it
causes aren't nearly as damaging as the other two things.
Check out the write-up though, and if you're not yet
up to section 46, just remember that you're going to want to
do something different with your U-1008 spacers. Maybe if
you're lucky, one of our great aftermarket parts sources will
come up with something before you get this far.
Tim Olson - RV-10 N104CD
Lew Gallagher
PostPosted: Sun Nov 07, 2010 7:06 pm    Post subject: Wheel Fairing Mount maintenance issue - a must-read for flyi Reply with quote
Great write up, Tim. Thanks, - Lew
non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed !
