bob(at)panth.co.uk Guest
Posted: Thu Nov 04, 2010 5:59 am Post subject: NSI CAP 140 IFA prop maintenance and spares |
Hello group,
I'm a would be Europa owner and am considering buying a plane with a
Rotax 912 engine and an NSI CAP140 IFA prop.
I know little about Europa's (other than they look good, fly well, and
have very loyal owners,) and I know even less about this prop, other
than I had heard a rumour that spares/ servicing might be a problem for
UK owners. Any info on servicing, spares, pre-purchase checking (and
anything else I should know) would be appreciated.
Apologies if this question has been answered somewhere in the archive
(I'm still learning how to drive this site)
Thanks (in anticipation)
rlborger(at)mac.com Guest
Posted: Thu Nov 04, 2010 6:40 am Post subject: NSI CAP 140 IFA prop maintenance and spares |
I would recommend a Google or other search on "NSI CAP 140 Propeller" to get as much background information as possible. I believe there may be a Canadian AD on the prop. NSI used to have a website ( http://www.nsiaero.com/ ) but it is no longer operating. Caveat Emptor.
Is it possible in the UK to replace the CAP 140 on a flying Europa with another prop (Warp Drive, Airmaster, Whirlwind, WoodComp, etc.)? Can this be done economically in this case?
Check six,
Bob Borger
Europa Kit #A221 N914XL, XS Tri-Gear, Intercooled 914, Airmaster C/S Prop
http://www.europaowners.org/forums/gallery2.php?g2_itemId=60232
http://www.biplaneforumgallery.com/index.php?cat=10046
Europa Flying!
3705 Lynchburg Dr.
Corinth, TX 76208
Home: 940-497-2123
Cel: 817-992-1117
On Nov 4, 2010, at 8:55, Bob Panther wrote:
Hello group,
I'm a would be Europa owner and am considering buying a plane with a Rotax 912 engine and an NSI CAP140 IFA prop.
I know little about Europa's (other than they look good, fly well, and have very loyal owners,) and I know even less about this prop, other than I had heard a rumour that spares/ servicing might be a problem for UK owners. Any info on servicing, spares, pre-purchase checking (and anything else I should know) would be appreciated.
Apologies if this question has been answered somewhere in the archive (I'm still learning how to drive this site)
Bob.Fairall(at)fairalls.c Guest
Posted: Thu Nov 04, 2010 7:00 am Post subject: NSI CAP 140 IFA prop maintenance and spares |
Hi Bob,
Try LAA Inspector - Dave Charlesworth ........ DCHARLESWORTH3(at)aol.com / +44 7876 745986
garrys(at)tampabay.rr.com Guest
Posted: Thu Nov 04, 2010 8:06 am Post subject: NSI CAP 140 IFA prop maintenance and spares |
I can enthusiastically recommend the Whirlwind constant speed prop. Those
who are running it will swear it's the best on the market. A little pricey,
but it you want the ultimate in performance, it's the way to go.
Garry Stout
Bob Borger
Hello group,
pete(at)lawless.info Guest
Posted: Thu Nov 04, 2010 9:53 am Post subject: NSI CAP 140 IFA prop maintenance and spares |
Hi Bob
NSI were bought out by Maxwell Propulsion some year back, Maxwell have
ceased trading recently. Although they never officially supported the
CAP140 they did have quite a number of spares. The blades are standard
Warpdrive and readily obtainable from them directly. However the cuffs are
NSI and would need to be refitted. There was an AD regarding the early
version of the cuff but they are now on Mark 3 with no issues. The original
problem was when the prop was fitted to I think Lycoming or Continental and
not Rotax or Subaru. There are still a few spares about but watch out for
spare blades where the Subaru ones turn the other way.
Very well engineered propeller with little to go wrong. Check for play in
the blades when it is static. It also suites the Europa flight
characteristics and performs well. Mine is on a 912 and we get 125kts
indicated at around 14.5 litres ph depending on load.
Pete
