marchudson(at)comcast.net Guest
Posted: Wed May 03, 2006 4:11 am Post subject: Dents in the HS skin |
Was wondering if anyone else had this problem and if there are suggestions
on how to fix it?
The nose ribs of the horizontal stab pull the skins in slightly and produce
a dent in the skins on the rivet line.
This is only happening on the top side of the skins not the bottom and only
to the nose ribs.
I have measured the worst looking one and it pulls the skin inward about 1/8
of an inch. I'm confident that
this is cosmetic only however it is still upsetting.
Will I be able to fill this in with Superfill before painting?
Has anyone else seen this?
I could e-mail pictures if needed.
Thanks for the help.
Marc Hudson
marcandkathy.com
Rick Galati
Joined: 10 Jan 2006 Posts: 90 Location: Lake St. Louis MO.
Posted: Wed May 03, 2006 6:30 am Post subject: Re: Dents in the HS skin |
| marchudson(at)comcast.net wrote: | Was wondering if anyone else had this problem and if there are suggestions
on how to fix it? The nose ribs of the horizontal stab pull the skins in slightly and produce a dent in the skins on the rivet line....... I'm confident that this is cosmetic only however it is still upsetting........Has anyone else seen this?....... |
Marc,
I addressed this fairly typical condition that can occur in one form or another. The heart of the problem is a gap that must be dealt with. I refer to you this recent thread with a fix I have frequently used with great success. http://www.vansairforce.com/community/showthread.php?t=6750
Rick Galati RV-6A "Darla"
jjessen
Posted: Wed May 03, 2006 9:11 am Post subject: Dents in the HS skin |
Yep. Got the same on my HS (RV-10). Mine are symmetrical, so looks
purposeful. My luck. Not sure how it'll be filled. Good question.
John Jessen (Tailcone)
wfinnell(at)earthlink.net Guest
Posted: Wed May 03, 2006 12:02 pm Post subject: Dents in the HS skin |
John,
I am sorry; I dont have any advice for you. I am just starting on my HS and was wondering if you could send me the photos so I can see what I have to look forward to?
Bill Finnell RV-8 Emp
smittysrv
Posted: Wed May 03, 2006 1:30 pm Post subject: Dents in the HS skin |
Hi Marc,
It looks like your RV-10 HS is very similar to my RV-9A HS. I had the same
issue on the HS. It seems that when one side of the skin gets riveted to
the rib, the opposite side will look distorted when riveted. I riveted the
top skin to the rib first and then the bottom skin to the rib. The top
looks good and the bottom is distorted. It's what on top that counts, I
guess.
Here's my entry about that situation:
http://www.smittysrv.com/more_stuff.asp?ID=231
Smittys RV-9A
http://SmittysRV.com
John,
to look forward to?
_________________ Smittys RV-9A
SmittysRV.com
dburton(at)nwlink.com Guest
Posted: Wed May 03, 2006 5:05 pm Post subject: Dents in the HS skin |
| Quote: | Was wondering if anyone else had this problem and if there are suggestions
There is a lot of info on the web about this. Randy Pflanzer has taken a
lot of time to give us some of his tips on building. He has built several
RV empennages (and several planes) and his website gives the techniques he
uses:
http://www.pflanzer-aviation.com/Hstab2.html
lsbrv7a(at)yahoo.com Guest
Posted: Wed May 03, 2006 6:18 pm Post subject: Dents in the HS skin |
Marc I have similar results. I suspect that my rib flanges were too square and did not fit the skin taper properly. I re-did my VS ribs at a relaxed angle to fit the skin tapper closely and the results were improved.
on how to fix it?
Sherman Butler
RV-7a Wings
Idaho Falls
New Yahoo! Messenger with Voice. Call regular phones from your PC and save big.
