Posted: Fri Nov 05, 2010 10:21 am Post subject: Adding crowbar to older Z-11 architecture |
At 04:33 PM 11/4/2010, you wrote:
Quote: |
I have been flying for several years with Z-11 (no alternator OV
disc. contactor) and an internally regulated alternator. I would
like to know whether the simple and inexpensive step of installing a
crowbar OV module as in Z-24 will provide OV protection. I have read
Bob's article on load dump damage and I am able to turn off my
alternator with the panel "OFF/BATT/ON" switch.
My thanks to Bob or anyone else who can answer my question.
The problem with adding ov protection for internally
regulated alternators is that there are failure modes
that cannot be controlled through the small wire.
So yes, some form of b-lead disconnect is called for
and Z-24 is one way to go about it. The load dump
thing is a bit of a red herring . . . first, there's
no NEED to flip the alternator on/off during normal,
loaded operations. Second, any IR alternator worth
it's salt will withstand a worst case load dump
many times in a row. See revision 12 chapter on
engine driven power sources in the 'Connection.
