dlm34077
Posted: Tue Nov 09, 2010 3:49 pm Post subject: Chelton and Trutrak VSGV |
We had been wondering why the lower selected altitude gave an immediate and uncomfortable descent. check the 6B operating procedures page 6-70.
"If a lower target altitude is selected, the skyway will descend
immediately and a green arc showing altitude capture point will
appear on the courseline on the MFD. The intent is to climb or
descend “right now” as if being given an assigned altitude from
ATC. This is analagous to the heading bug submode. The
system uses descent logic. This will be either a manually-
selected vertical speed (VSI bug) or airspeed (airspeed bug). If
neither is selected, a default descent of 1000 fpm will be used."
Climb and descent angles appear to work only for VNAV segments.
