dlm34077
Posted: Sun Nov 07, 2010 1:03 pm Post subject: descent profile |
While in the LS/VS mode and using the Cheltons for control of the TT AP VSGV and aircraft, I get more descent rate than I requested. I am using the target altitudes as descend to /climb to altitudes. I set descent/climb angle on the Cheltons. The initial descent is an uncomfortable descent profile even though I told the Cheltons a descent of less than 1 degree. The only thing that seems to shallow the descent is reduction in maximum air speed defined to the TT . I probably have a parameter improperly specified. Any suggestions?
gengrumpy(at)aol.com Guest
Posted: Sun Nov 07, 2010 1:13 pm Post subject: descent profile |
I've seen similar issues with mine.
I've tried setting degree as well as FPM, and FPM seems to work a bit better than degree.
Like you, Dave, there is probably something I'm missing as well.
Maybe Tim the Master can get us both on track??!!
grumpy
On Nov 7, 2010, at 2:59 PM, DLM wrote:
| Quote: | While in the LS/VS mode and using the Cheltons for control of the TT AP VSGV and aircraft, I get more descent rate than I requested. I am using the target altitudes as descend to /climb to altitudes. I set descent/climb angle on the Cheltons. The initial descent is an uncomfortable descent profile even though I told the Cheltons a descent of less than 1 degree. The only thing that seems to shallow the descent is reduction in maximum air speed defined to the TT . I probably have a parameter improperly specified. Any suggestions?
dlm46007(at)cox.net Guest
Posted: Mon Nov 08, 2010 6:56 am Post subject: descent profile |
I will try the VS Chelton input soon; I did talk to TT and they said to check the AP standalone without any Arinc A or B input using the knob to specify descent rates
