sfarner(at)gmail.com Guest
Posted: Wed May 03, 2006 10:27 pm Post subject: Alternator pulley and flywheel misalignment SOLVED |
Hey guys,
Thanks for all of the responses. I came up with a low cost (well, zero cost
since I had all of the materials) solution that only took an hour or so to
finish.
Basically, what I did was flip Van's alternator bracket around and fabricat=
e
a new bolt mount from some angle stock.
I put together the procedures on my web site for reference.
www.scottfarner.com/showpage.asp?date=3D5/3/2006
Scott
On 5/3/06, Dave Cudney <yenduc(at)sbcglobal.net> wrote:
Scott:
I just took another look at your picture. I thought you were
referring to the
gap and not the misalignment. It looks like your ring gear is
pushed all the way on and sets inside of the alt pulley. I just
looked at mine.
Your 60 amp alt looks a bit different than mine and protrudes further
forward from
the mounting boss. You might want to give Vans a call.
Sorry
dave
On May 3, 2006, at 8:13 PM, Dave Cudney wrote:
> I ran into the same problem last week with my RV 7A with a superior
> io 360.
> I cut a spacer out of 1/4" aluminum stock to fill the gap --- it
> worked just fine. Check
> the length of the bolt to make sure you have enough threads for a
> good grip --
> you may need to get a longer bolt -- mine fit fine. I note that
> others have made a
> double bend (an "S") in the brace to accommodate the gap.
> Dave(at) RAL
> On May 3, 2006, at 3:11 PM, Scott Farner wrote:
>> Listers,
>> I was installing the alternator (60 amp from Van's) on my IO-390
>> using the
>> supplied bracket and noticed that the alternator pulley is offset
>> about
>> 5/16" forward of the flywheel. The bracket also overhangs the boss
>> mount on
>> the engine by about this amount, and there is the same deal on the
>> bracket
>> connecting the alternator to the starter.
>> Here is a picture of what I am talking about:
>> www.scottfarner.com/altflywheel.JPG
>> Anybody run in to this problem and come up with a fix?
>> Thanks,
>> Scott Farner
>> www.scottfarner.com
>> RV-7A Engine
=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=
Posted: Thu May 04, 2006 7:17 am Post subject: Alternator pulley and flywheel misalignment SOLVED |
Hey guys,
finish.
e
Scott
Posted: Thu May 04, 2006 1:45 pm Post subject: Alternator pulley and flywheel misalignment SOLVED |
Sorry, link should have been
Scott
On 5/4/06, Scott Farner <sfarner(at)gmail.com> wrote:
Hey guys,
cost
since I had all of the materials) solution that only took an hour or so t=
o
| Quote: | finish.
fabricat=3D
e
www.scottfarner.com/showpage.asp?date=3D3D5/3/2006
Scott
retasker(at)optonline.net Guest
Posted: Thu May 04, 2006 3:24 pm Post subject: Alternator pulley and flywheel misalignment SOLVED |
How about: http://www.scottfarner.com/showpage.asp?date=5/3/2006
(hopefully no "3D")
Dick Tasker
Scott Farner wrote:
Scott
>Hey guys,
>cost
o
>finish.
>fabricat=3D
>e
>Scott
Posted: Thu May 04, 2006 3:39 pm Post subject: Alternator pulley and flywheel misalignment SOLVED |
That's what I typed in when I sent it; don't know how the "3D" keeps gettin=
g
thrown in there.
Scott
On 5/4/06, Richard Tasker <retasker(at)optonline.net> wrote:
How about: http://www.scottfarner.com/showpage.asp?date=3D5/3/2006
(hopefully no "3D")
Dick Tasker
>Scott
>>Hey guys,
>>cost
t=3D
>o
>>finish.
>>fabricat=3D3D
>>e
>>www.scottfarner.com/showpage.asp?date=3D3D3D5/3/2006
>>Scott
>=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=
| Quote: | >=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D
Posted: Thu May 04, 2006 6:15 pm Post subject: Alternator pulley and flywheel misalignment SOLVED |
It is something your mail system is adding. The message that I sent
has no "3D" in it when I received it. Your answer to my mail message
has the "3D" inserted again.
Dick
Scott Farner wrote:
g
thrown in there.
Scott
>(hopefully no "3D")
>Dick Tasker
>>Scott
>>>Hey guys,
>>>cost
>t=3D
>>o
>>>finish.
>>>fabricat=3D3D
>>>e
>>>Scott
Please Note:
No trees were destroyed in the sending of this message. We do concede, however,
that a significant number of electrons may have been temporarily inconvenienced.
