lgds(at)post6.tele.dk Guest
Posted: Tue Nov 09, 2010 9:38 pm Post subject: Blue foam ... ?? |
Hi all
Anyone know where to purchase the blue foam .. ??
Regards Gert
OY-GDS / 914 / mono
Posted: Tue Nov 09, 2010 9:45 pm Post subject: Blue foam ... ?? |
Hi all
Anyone know, where to purchase the blue foam .. ??
Regards Gert
OY-GDS / 914 / mono
Posted: Wed Nov 10, 2010 3:35 am Post subject: Blue foam ... ?? |
Hi! Gert.
I used some blue thermal building block insulation, it's slightly more dense
but quite adequate for a small construction or filler. There's probably more
than you want in a builders waste bin of off cuts.
It's called "Kingspan" here.
It's better than being stuck for a supplier.
Bob Harrison G-PTAG
neveyre(at)aol.co.uk Guest
Posted: Wed Nov 10, 2010 2:46 pm Post subject: Blue foam ... ?? |
It is manufactured by Dow, as insulation Styrofoam, 2lb cu'ft.
Google for local supplier.
Cheers,
Nev.
g-iani(at)ntlworld.com Guest
Posted: Thu Nov 11, 2010 2:23 am Post subject: Blue foam ... ?? |
If you want a small amount I would try builders local to you first, most have some spare
I believe the blue foam is Alcan Airex C70 but check that it is C70
White foam is Airex R63
These are available from
Impag (UK) Ltd
Draycott Business Park
Cam
Dursley, GL11 5DQ
01453 89077
Ian Rickard G-IANI XS Trigear, 300hours
Europa Club Mods Specialist
e-mail g-iani(at)ntlworld.com
