Is the rudder hinge perpendicular to the horizontal level li
Mauledriver(at)nc.rr.com
PostPosted: Wed Nov 17, 2010 10:15 am    Post subject: Is the rudder hinge perpendicular to the horizontal level li Reply with quote
Does anyone happen to know if the rudder hinge line is perpendicular to
the door sill?
I understand the door sill is the horizontal datum line. It appears to
be lined up with the cowling hinge line. And it appears to be normal to
the rudder hinge line as well as being aligned with the rivet lines on
the rudder.
Not a critical question, just laying out some trim lines and triple
checking my observations.
Bill "happiness is a warm shop" Watson
(now downloadable on iTunes if you don't already have it)
