cgroote1(at)yahoo.com Guest
Posted: Fri Nov 26, 2010 7:40 am Post subject: And another iPad question |
I, too, am thinking about getting an iPad, mainly for charts. Foreflight recommends the iPad Wifi + 3G (this unit has an internal GPS receiver). However, they state that an external GPS source is sorely needed and recommends getting the Bad Elf GPS to use with it.
Verizon's iPad is Wifi enabled with an external Mifi router mobile hotspot. So, you have essentially the same thing along with Verizon's across the country coverage. Seems to me this is the better way to go. Am I missing something?
Tim Olson
Posted: Fri Nov 26, 2010 8:50 am Post subject: And another iPad question |
I don't think any of you are missing anything. You all have
good points, and have pointed out good info. I'll try to show
my reasonings and point out how all your points fit.
First, it's all about options. If you don't get the 3G,
you're missing a couple of options...
Kelly (and Foreflight) is right. The built-in GPS isn't
fantastic in quality. It does, however, work reasonably
well and would probably do all you need, much of the time.
For in-flight navigation, if you don't already have an
EFIS doing all your precision work for you, you'd want
either the Jailbreak+Bluetooth GPS (which are usually WAAS),
or one of the 2 options for attached WAAS GPS's. This
would give you real precision. If you already have the
approach on the EFIS, it really isn't that big of a deal
to go through the trouble of the external GPS. The built-in
one is usually accurate for me within maybe 50'. Personally,
I feel your best option is to do both...have the 3G with
GPS, and also have an external. More on that...
Regarding the 3G, yeah, for me especially in our area, AT&T
sucks badly. But, when we travel, we often end up in
areas where AT&T works and works well. We bring the iPad
and on the larger trips and for OSH, we'll activate the
AT&T 3G plan for a month. It gives some great useability
in the car. We'll drive along looking for something,
and on google maps just google something like
"quality suites" and it'll drop pins on the map, and
we can click them and get directions and phone info
right on it. Looking for the Monterey Aquarium? Just
google-map it and it's there. So it's very handy to do
the 3G thing at times. We've only used it for 2 or 3
months in the last year, but when we wanted it, it was
there, and we didn't have to carry any attachable devices
to use it. That's worth something too.
Regarding MiFi and the like... I also have a mini router,
which I bet is probably the OEM source for the MiFi...not
sure on that. Cradlepoint.com though, check it out. I have
the PHS300, and for work, I have a verizon air card, which
is a USB cell device that plugs into the PHS300, or into
your laptop, giving you 3G coverage through Verizon. Around
here, that works way better than AT&T. It certainly works
REALLY well when traveling though, in that it's a normal
hotspot router, so I can get everyone in the family online
with their ipod touches, and laptops. So they're very very
handy to have...and yes, with that, I don't really need
to use the 3G. That said, it's still very nice to not
always have to remember those additional parts, and just
activate 3G. When I was in Monetery, I found times when
I had to switch to verizon, or AT&T, depending on my
location, to get good coverage. Neither provider gives
you 100% coverage.
Another thing that you can do with Jailbroken devices, like
my iphone and an iPad with 3G, is install MyWi, which lets
you share your 3G like a wi-fi hotspot. So, we've been on
trips where I activated the iPad 3G, and shared THAT 3G
coverage with the family or my laptop. And, I've found it
convenient to do the same from my iPhone, or just tether
it with the charging cable and do it that way, to my
laptop. It's something you can do with Jailbroken devices,
or pay AT&T an ungodly high rate for if you don't want to
jailbreak.
Also, regarding the iPad, if you buy any of the charting
apps, you'll want some space. 16GB will likely be fine,
but, if you want to go multi-purpose and have options once
again, get the big one. We completely fill our 64Gb iPad.
It's full of movies for the kids, music, and charts, mostly.
I have Foreflight HD, which is my favorite app. Makes for
awesome in-flight charts and approach plates, and all the
info that you'd need, in probably the best presentation
graphically of all the apps. Very nice for planning and
filing. Then there's WingX Pro 7. Over a year ago I used
WingX just to try it out, on the iphone. It was nice, but
they are as ugly as can be when it comes to colors and
graphical design on the iphone app. Today I bought a
Seattle Avionics lifetime iPad IFR data subscription since
they offered it for Black Friday. With that, I decided to
also spend the money to buy 12 months of WingX Pro 7,
plus another $30 for fuel price info. Foreflight does
much of what WingX does, but not all of it, and vice versa.
But, since I hate buying chart data, I figured today was
the day to waste a little cash and just do it...since
it was lifetime data. From playing with WingX, it looks
like when actually flying an approach, I'll probably use
their software. Since the fuel price info is cached, it's
useable in flight. I'll probably use foreflight for all
my pre planning, filing, weather planning, and for looking
at sectionals in flight. Then when it comes to flying
the approach, since today WingX has georeferenced approach
plates and actually a real nice split-screen view option,
I'll use that. I do believe that Foreflight will be coming
out with georeferenced approach plates though, so the money
I spent today was partially a waste. The Seattle Avionics
iPad data subscription is portable to their partner's apps,
WingX being one. My hope is that this will extend to
Foreflight if they partner in the same way. Again, it's
all about options...this time in software.
So while you can certainly save money and not get a 3G
model, I think it's great to not HAVE to bring my
Cradlepoint+verizon hotspot all the time, and not HAVE
to remember a bluetooth GPS, or any add on hardware. It's
nice when you want to be slim and trim to be able to
just grab the ipad on it's own, and have what you need to
get by. And, considering there are ways you can share the
3G service it offers with your other devices, it really
makes it possible to have ONLY an iPad 3G model and
no accessories, and still get the job done if you need.
To me, I'd rather spend a little more up front and have
more options. Wouldn't it stink if you had an add-on GPS,
and suddenly when you need it, you forgot it, or it went
titzup? AS SOON AS verizon gets the iPhone, I plan
to drop my AT&T iphone and get one. That will give me
both Verizon and AT&T 3G options, even without bringing
my Cradlepoint hotspot. That will help ensure I always
have one of the 2 providers with the least of accessories.
So yeah, there are more than 2 or 3 ways to skin cats
(although I just roast them fur on, with barbecue sauce <g>)
and all have good points. It's just a matter of making
sure you see all of the potential things you may want to
do some day, and which tools you should have in your toolbox
to get you to what you need.
IMHO, none of the stuff you can get on an ipad really replaces
what you REALLY want to have....and that's a good EFIS,
with integrated weather, for in-flight use.
Tim Olson - RV-10 N104CD
On 11/26/2010 9:37 AM, curtis groote wrote:
| Quote: | I, too, am thinking about getting an iPad, mainly for charts.
dlm46007(at)cox.net Guest
Posted: Fri Nov 26, 2010 10:50 am Post subject: And another iPad question |
I bought the 64GB; I am using considerably less memory even with some albums on there for IPOD. I suggest the 32GB or possibly 8GB with 3G, WiFi and GPS. It seems that the charts part of Foreflight only takes about 2GB? Somebody who has synced and look at your PC could probably say for sure what Foreflight takes. For me it is the only significant data storage app for me.
