Posted: Fri Nov 26, 2010 7:36 pm Post subject: Off Topic--FAA Rulemaking |
This just popped up on my radar. I hadn't heard anything about it.
http://edocket.access.gpo.gov/2010/2010-27834.htm
To summarize, A&Ps with an Inspection Authorization (IA) currently
have to be "actively engaged" in the industry to be eligible to renew
their ticket. This proposal would redefine "actively engaged" as
full time employment. Otherwise, you get to have your status
evaluated by an FAA inspector who then decides if you are sufficiently
engaged.
And, since FAA inspectors aren't "actively engaged", they get to
automatically keep their IAs to use when no longer employed by FAA.
Pass this on to any IAs you know. The comment period closes December 6th.
Dave Saylor
AirCrafters
140 Aviation Way
Watsonville, CA 95076
831-722-9141 Shop
831-750-0284 Cell
AirMike
Posted: Sun Nov 28, 2010 9:20 am Post subject: Off Topic--FAA Rulemaking |
Dave - thanks for letting us know about this - I sent the following to the FAA.
I object to the actively engaged provisions of this clarifying definition. While I fly an experimental aircraft and do my own inspections, I formerly owned a certified aircraft and may again in the future. This proposal (if implemented) would make it more difficult and expensive to obtain an IA sign-off on an annual inspection. Many retired or semi-retired IA's can do a very competent job of "annualing" a certified aircraft. To summarily kick these people out of the aviation community by pulling their authorization would be doing aviation a great disservice. I see no safety benefit in this proposal.
_________________ See you OSH '18
Q/B - sold. |
Tim Olson
Posted: Sun Nov 28, 2010 9:45 am Post subject: Off Topic--FAA Rulemaking |
Short and sweet and to the point. I'll copy what you said and sent in the same.
On Nov 28, 2010, at 11:20 AM, "AirMike" <Mikeabel(at)Pacbell.net> wrote:
See you OSH '11
Q/B - flying 1 yr+
http://forums.matronics.com/viewtopic.php?p=321401#321401
dlm46007(at)cox.net Guest
Posted: Sun Nov 28, 2010 10:10 am Post subject: Off Topic--FAA Rulemaking |
BTW if you want to object to something ; object to the 99 year comment
period assigned to the eliminaton of the 3rd class medical.
