Posted: Sun Dec 05, 2010 6:07 pm Post subject: MT prop Governor set screw |
ON the top of the MT governor is a set screw which allow the servo arm to be reoriented to the correct angle per different installations.
Seing that MT is a German company, I thought that the set screw was a metric allen wrench. I appears that non of the metric allen wrenches I purchased are of the correct size. Also, by chance I thought that it might be a star drive and it isn't that either, at least not in standard sizes.
Does anyone know what tool will losen this set screw and is the set screw standard clockwise rotation for tightening and counterclockwise for loosening.??
John
lessdragprod(at)aol.com Guest
Posted: Sun Dec 05, 2010 6:24 pm Post subject: MT prop Governor set screw |
Don't remove the governor arm!!!!!!!!!
Cut the safety wire on the six screws behjnd the governor arm.
LOOSEN the six screws.
Rotate the governor arm and stop assembly to the position you want.
Tighten the six screws.
Safety wire the six screws.
Jim Ayers
Less Drag Products, Inc.
An MT Propeller distributor
Posted: Sun Dec 05, 2010 6:40 pm Post subject: MT prop Governor set screw |
Hi Jim,
What is that single screw on the top of the unit??
Subject: Re: MT prop Governor set screw
Date: Sun, 5 Dec 2010 21:20:56 -0500
Jim Ayers
Posted: Sun Dec 05, 2010 8:26 pm Post subject: MT prop Governor set screw |
I believe you are asking about a plug in the top of the governor unit. A flush fitting requiring an allen wrench to remove?
A fitting can be installed at this location to attach an accumulator to the inlet side of the governor.
During zero "G" maneuvers, prolonged vertical maneuvers, or whenever oil pressure is lost, the accumulator will provide the required inlet pressure to the governor so the propeller functions properly (for perhaps 10 seconds.)
Posted: Sun Dec 05, 2010 8:33 pm Post subject: MT prop Governor set screw |
Hi John,
I should have mention that the plug is a standard pipe thread plug, and not metric. A standard AN fitting is used to go from the pipe thread to a flare tube end.
Unless you are installing an accumulator, there shouldn't be any need to remove this plug.
Jim Ayers
pilotdds(at)aol.com Guest
Posted: Sun Dec 05, 2010 9:22 pm Post subject: MT prop Governor set screw |
what happens if the set screws are removed and the arm is removed and replaced.
Posted: Sun Dec 05, 2010 9:33 pm Post subject: MT prop Governor set screw |
Thanks Jim.
I will not need to do anything with this plug, I just would like to know what it is for.
I a three to four months hopefully I'll have the plane at Camarillo and I'll have you come over and torque my propellor bolts.
Thanks for your help
Date: Sun, 5 Dec 2010 23:28:12 -0500
Hi John,
Jim Ayers
Posted: Mon Dec 06, 2010 8:11 am Post subject: MT prop Governor set screw |
If the arm is removed and replaced in exactly the same orientation, nothing
