Rotax revised Service Instruction SI-912-020 / SI-914-022 Re
trigo(at)mail.telepac.pt
PostPosted: Sun Dec 05, 2010 4:37 am    Post subject: Rotax revised Service Instruction SI-912-020 / SI-914-022 Re Reply with quote
Is everybody aware of the many modifications suggested by this Service
Instruction?
http://www.rotax-owner.com/pdf/SI-912-020-R4.pdf
Carlos
rampil
PostPosted: Mon Dec 06, 2010 10:19 am    Post subject: Re: Rotax revised Service Instruction SI-912-020 / SI-914-02 Reply with quote
Most of the factory-line improvements are strictly optional, at least
2 deal with inability of the factory to get discontinued parts, so new parts
and fittings are spec'd. If you already have an engine, then you have the
sensors in question and do not need replacement (unless they break).
No need to change working fuel lines either as the SI notes.
Actually I did not see anything that was mandatory, or even recommended
in this list, but I could be wrong Wink
Ira N224XS
