680FLP
yourtcfg(at)aol.com
PostPosted: Wed Apr 25, 2012 7:05 am    Post subject: 680FLP Reply with quote
"Calling Tom Fisher, over" Tom, I am delivering your old 680FLP to FL. It is currently at my home airport. How does the heater work?? Is there a switch or valve that needs moved? I have done the obvious, turn the switch on and the heat up,. The light illuminates, but no heat. It even smells like it may be making heat, but none enters the cabin??? Thanks jb [quote][b]
tfisher(at)commandergroup
PostPosted: Wed Apr 25, 2012 9:07 am    Post subject: 680FLP Reply with quote
Gee I wish you had let me know when you were going to come here.
The heater is a brand new digital heater, I used it once, have no idea what may be out of kilter, the engineer that put it in is no longer around, sorry.
T...
tylorhall(at)mac.com
PostPosted: Wed Apr 25, 2012 3:18 pm    Post subject: 680FLP Reply with quote
JB and Tom,Great to here another one is back into the air.
Have a good flight JB.
Tylor
On Apr 25, 2012, at 11:06 AM, Tom Fisher wrote:
[quote]Gee I wish you had let me know when you were going to come here.
T...
[quote]---
stratobee
PostPosted: Wed Apr 25, 2012 5:42 pm    Post subject: Re: 680FLP Reply with quote
Tight squeeze getting her out of your field, JB!
Adam
yourtcfg(at)aol.com
PostPosted: Wed Apr 25, 2012 8:14 pm    Post subject: 680FLP Reply with quote
Yep probably will be.� Lots of HP but little thrust. Should be fine but wont have any room for trouble. jb
Sub22
PostPosted: Mon Feb 10, 2014 5:27 pm    Post subject: Re: 680FLP Reply with quote
Try slow fighting, nose up. Then try heater ignition. It's worked for me a few times. -30°F
Does it fire up in warm air?
JS Bennett
RPMCommander
PostPosted: Mon Feb 10, 2014 10:38 pm    Post subject: Re: 680FLP Reply with quote
turns out it had alot to do with the airconditioner that was mysteriously removed. Thats all I will say.
