Posted: Sat Dec 11, 2010 9:35 am Post subject: Headset storage |
I am in the late stages of an 8A build. As we all know the cockpit is… snug. I am looking for a way to store two headsets on the right side of the cockpit so they are out of the way but when we are entering / exiting the aircraft. I have seen a simple fabric loop & snap that seemed to be simple and difficult to damage. I have designed in my head a couple of other options (swinging arm and spring loaded arm) both of which live under the canopy rail ledge and are moved into place when they are needed. Unfortunately they have the potential disadvantage of being damaged when misused.
Any suggestions on a headset storage bracket or device for the 8 would be appreciated.
Robin
Panel to date:
59.54 KB |
2189 Time(s) |
Posted: Sun Dec 12, 2010 8:45 am Post subject: Headset storage |
Robin(at)PaintTheWeb.com Guest
Posted: Mon Dec 13, 2010 12:01 am Post subject: Headset storage |
Linn,
I see a reply to the Headset storage request but the contents were
blank. Did you have something to share?
Robin
Posted: Mon Dec 13, 2010 5:15 am Post subject: Headset storage |
I just hate that!!! For those blank emails, if you click view on the
menu bar (for my client anyway) you can view 'message source' and find
the text buried in a whole lot of useless info. TMI comes to mind!
Anyway, I went to the 'sent' folder to see what I said (I did remember,
just wanted to see what it was) and my message appears to be sent that
way ..... with the content hidden! My bad. I'll see what to do about a
fix. I did the above stuff.
Oh yeah, you had a question!!!
My first thought is a bracket attached by the upper right hand screw that's to the
right of the displays.
Linn
Now I do have concerns about stuff sticking out of the panel lest your head find it in a sudden deceleration (crash) but that may be off to the side far enough.
