budyerly(at)msn.com Guest
				 Posted: Tue Dec 14, 2010 5:42 pm    Post subject: Europa fuel tank - Removal |
				<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]-->  Will,
  Not to worry, I think we have a fix.
  If the tank must be replaced, it takes a three day weekend (not including  interior replacement), although I spent a week.  With the  tank out I was able to play with some other things in that hole I preferred  to do differently....
  I have some pictures of the removal, somewhere showing how I cut it  out and replaced it.  I have done three at the shop over the years (mine  cracked and the other two had holes drilled in them by accident)  and it is  not that bad...  Just a technique and of course knowing where to cut to  avoid all those wires you may have run through there.
  In the next month or so, when the dust settles, I will do a how to as part  of the tech help series and discuss why the old tanks fail...  It is the  lack of bottom support and variances in construction which my autopsy of the  tank revealed causes the split(s), as well as some hardening of the tank when  left without fuel for some time, and when refilled, the tanks lack of support on  the front and bottom forces a stress riser at the rear.  More of that  later....
  Give me a few weeks, much to do in the shop and airshows to get ready for  and not enough hands or mind.
  By the way, with the new tank, I can just hold 20 gallons to the filler  neck in my trigear vs. the 18.5 from before.  The old tank had a depressed  top and the new tank was very straight and true, it's a bit wider (read as I had  to cut the rails a bit) and has small diagonal support moldings which accounts  for the slight bit of extra gas.
  Bud Yerly  Europa Tech Support.
 Custom Flight Creations,  Inc.
 www.customflightcreations.com
 (813) 653-4989
  [quote]   ---
