Joe(at)hambrothers.com Guest
Posted: Tue Dec 14, 2010 1:01 pm Post subject: canopy side frame 601xl |
help how to fasten side flashing 6c3-3 at ea end heard mintion of
glue at some point if so what type.
thanks
Joe Ham
bryanmmartin
Posted: Fri Dec 17, 2010 3:45 pm Post subject: canopy side frame 601xl |
On mine, I put the front edge under the front flashing. I used 3M molding tape between the upper edge of the front flashing and the plexiglas. I put the rubber trim strip over the rear end of 3C3-3 and used 3M weatherstrip adhesive under the flashing in that area and to attach the rubber trim to the canopy. This has worked very well for me.
3M molding tape is a gray foam double sided tape designed to attach vinyl moldings on the sides of cars.
3M weatherstrip adhesive is a rubbery contact adhesive. You put it on both surfaces and let it dry to a tacky state and then press the two pieces together.
On Dec 14, 2010, at 3:57 PM, Joe wrote:
Quote: | help how to fasten side flashing 6c3-3 at ea end heard mintion of
thanks
Joe Ham
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus re-drive.
do not archive.
_________________ --
Bryan Martin
do not archive. |
