peterz(at)zutrasoft.com Guest
Posted: Fri Dec 10, 2010 10:49 am Post subject: Europa fuel tank - LDPE or HDPE? |
Would anyone know which it is? (I think I had heard LDPE)
I am asking because I am about to spend some money getting my still uninstalled tank Fluorinated or Re-Fluorinated - since I cannot be sure to what level it was done by the Europa factory (if it was done at all back in 2000) and I wish to avoid the swelling and cracking problems some are seeing in service.
I am choosing to Fluorinate to the same level (AL) as the auto industry (by Fluoro-Seal International LP)
Thanks in advance,
Pete
A239
Ottawa Canada [quote][b]
craigb(at)onthenet.com.au Guest
Posted: Fri Dec 10, 2010 2:12 pm Post subject: Europa fuel tank - LDPE or HDPE? |
my kit is from 2000 as well, and i asked the factory (before the merger) back in 2008 if my tank fell into the post non fluorinated time frame, and they
responded this after i indicated the desire to purchase a new fluorinated tank. so based on what i was told i would believe yours should be ok. If its not
much cost involved the second treatment would probably be a good investment.
regards
craig
[quote] --
jan_de_jong(at)casema.nl Guest
Posted: Fri Dec 10, 2010 2:34 pm Post subject: Europa fuel tank - LDPE or HDPE? |
Introduction of fluorination was in April 1997:
http://www.sarangan.org/www/mhonarc/mharc/html//europa-list/1997-08/msg00096.html
I have assumed that my tank from the year 2000 was treated and did not
repeat it. In any case any spilt epoxy bonds to it extremely well (as
well as to itself) - which is supposed to be a side effect of fluorination.
Jan de Jong
craig bastin wrote:
[quote] my kit is from 2000 as well, and i asked the factory (before the
investment.
regards
craig
Posted: Sun Dec 12, 2010 5:18 pm Post subject: Europa fuel tank - LDPE or HDPE? |
thanks all for the info/links. Looks like mine *should* have been done, but since I still don't know to what level, I decided to go get it done again, this time to automotive level standards.
Based upon the softness of the tank material, I presume it is LDPE.
Cheers & thx,
Pete
A239, building finally starting in earnest.
On Fri, Dec 10, 2010 at 5:28 PM, Jan de Jong <jan_de_jong(at)casema.nl (jan_de_jong(at)casema.nl)> wrote:
[quote]--> Europa-List message posted by: Jan de Jong <jan_de_jong(at)casema.nl (jan_de_jong(at)casema.nl)>
I have assumed that my tank from the year 2000 was treated and did not repeat it. In any case any spilt epoxy bonds to it extremely well (as well as to itself) - which is supposed to be a side effect of fluorination.
Jan de Jong
craig bastin wrote:
[quote]my kit is from 2000 as well, and i asked the factory (before the merger) back in 2008 if my tank fell into the post non fluorinated time frame, and they
regards
craig
Posted: Sun Dec 12, 2010 5:48 pm Post subject: Europa fuel tank - LDPE or HDPE? |
Peter,
Since your tank is yet to be installed, I expect that you will be taking it somewhere for treatment. As one w/ an installed but yet to be filled w/ fuel tank of similar vintage, I'm wondering about the treatment you anticipate and how it is done...(?)...Is it something which conceivable could be accomplished on an installed tank if the fuselage were trailered to a facility which does this sort of thing?
I wouldn't expect the treatment would be offered at the neighborhood "gaairage" (phonetic sp.? lol), but I've no idea what type of facility does this sort of work...do you live near a factory which supplies the auto industry?
Please keep us posted on this,
Fred
On Dec 12, 2010, at 5:13 PM, Peter Zutrauen wrote:
[quote]thanks all for the info/links. Looks like mine *should* have been done, but since I still don't know to what level, I decided to go get it done again, this time to automotive level standards.
Cheers & thx,
Pete
Jan de Jong
regards
craig
Posted: Mon Dec 13, 2010 4:11 am Post subject: Europa fuel tank - LDPE or HDPE? |
Hi Fred,
Indeed it is an industrial process on the loose piece-parts in temperature/pressure controlled chambers filled with controlled volumes of Fluorine. Different parameter combinations for different levels of fluorination (they have 9 different levels). They typically are set up to do large mfg runs of auto gas tanks, plastic gerry cans, shampoo bottles etc.etc. so I'm eating a minimum charge (which they somewhat reduced for me) which is distasteful but understandable, and worth my piece of mind (hopefully preventing me from potentially hacking out my tank 5-10 years down the road.). If I had 4 tanks or so, I could have done it much more cost effectively.
They have 4 facilities which can do the Auto-tank level, and I chose their Atlanta plant for it's relative proximity.
I'll keep folks posted how it goes and can provide contact info for any interested.
Cheers,
Pete
A239
On Sun, Dec 12, 2010 at 8:45 PM, Fred Klein <fklein(at)orcasonline.com (fklein(at)orcasonline.com)> wrote:
[quote] Peter,
Fred
Cheers & thx,
Pete
Jan de Jong
regards
craig
asarangan(at)gmail.com Guest
Posted: Mon Dec 13, 2010 12:49 pm Post subject: Europa fuel tank - LDPE or HDPE? |
Pete,
My tank is probably flourinated since I got it after 2000. However
since I haven't fitted my tank in yet, so I may be interested in
getting the extra treatment done. What is the cost? If it is not too
expensive, I could be convinced to split the cost.
On Mon, Dec 13, 2010 at 7:06 AM, Peter Zutrauen <peterz(at)zutrasoft.com> wrote:
[quote] Hi Fred,
cost effectively.
interested.
Cheers,
Pete
A239
On Sun, Dec 12, 2010 at 8:45 PM, Fred Klein <fklein(at)orcasonline.com> wrote:
> Peter,
> industry?
> Fred
> Cheers & thx,
> Pete
> On Fri, Dec 10, 2010 at 5:28 PM, Jan de Jong <jan_de_jong(at)casema.nl>
>> Jan de Jong
>>> they
>>> be ok. If its not
>>> investment.
>>> regards
>>> craig
Posted: Mon Dec 13, 2010 2:35 pm Post subject: Europa fuel tank - LDPE or HDPE? |
On Dec 13, 2010, at 4:06 AM, Peter Zutrauen wrote:
Quote: | Indeed it is an industrial process on the loose piece-parts in
Thanks Pete...not a surprise, but I had a tiny hope that the process
might have just entailed "filling up" w/ Fluorine...shakin it up a bit
so the fluid/gas (?) could shlosh around a bit...and letting it drain
(in my dreams!)...oh well...Fred
wdaniell(at)etb.net.co Guest
Posted: Tue Dec 14, 2010 5:38 am Post subject: Europa fuel tank - LDPE or HDPE? |
Oh dear....mine is already in but it seems the problem is not universal.
Just out of interest how on earth do you get it out once the airplane is built around it?
Will
hagargs(at)earthlink.net Guest
Posted: Wed Dec 15, 2010 8:02 pm Post subject: Europa fuel tank - LDPE or HDPE? |
Peter:
Have you sent your tank in yet? I being one who having to "hack my tank out" have a tank that I bought a couple of years ago from Bob Berube. I don't know how long he had it so its processing is questionable. I had been planning on fabricating a metal tank for installation when I got around to it so the new plastic tank has been sitting around to be used as a model. However I may change my mind and put the stock item in it would be good to have the proper processing on it. If the lot charge could be spread over 2 or more tanks it would be beneficial. Please get with me if this is something to be considered.
Thank you ,
Steve Hagar
A143
Mesa AZ
hagargs(at)earthlink.net (hagargs(at)earthlink.net)
Posted: Thu Dec 16, 2010 4:00 am Post subject: Europa fuel tank - LDPE or HDPE? |
Hi Steve,
Yes, my tank is en-route. As I've been advised from them that if the tank is not free of contaminants (I had to clean mine inside and out with naphtha/methanol - nasty) it could be damaged in the process (over-heat from a reaction with contaminants), I'd recommend that we wait and see how mine goes. Also, I've asked them to produce an accurate costing for my tank (and filler snake) with the prospect of doing a few more (grouped together) for any other builders out there.
One interesting comment by their technical adviser I thought may have some merit: when he was examining pictures of my tank for a cost estimate, he advised me that all cuts/openings to the tank must be done prior to the process, or any exposed freshly cut surface will be an entry point for the absorption of fuel into the MDPE plastic. This is because the fluorination treatment is only a surface treatment. So if one takes his opinion as valid, even if the tanks have been treated to an adequate level by Europa, cutting into them after-wards drastically diminishes the treatment's effectiveness.
I'll keep the list updated on the outcome of my tank's adventure, and group pricing for anybody interested. Of course I won't likely know how effective it has been for another 10 years or so
Cheers,
Pete
A239
Ottawa, Canada
PS - when I asked the cynical question of "how do I know you even did anything" I received the following (reassuring?) reply:
"Regarding your assurance that your tank has been treated properly, we do not ship any items to any one of our customers without our QC measures in place. Through use of a Thermo Electron Fourier Transform Infrared Spectrophotometer (FTIR) the ratio of available hydrogen sites that have been replaced with fluorine in comparison to the available hydrogen sites that have not been replaced with fluorine can be measured. Every item treated by us must pass our QC before it is released for return shipment. "
On Wed, Dec 15, 2010 at 10:58 PM, Steve Hagar <hagargs(at)earthlink.net (hagargs(at)earthlink.net)> wrote:
[quote] Peter:
Thank you ,
Steve Hagar
A143
Mesa AZ
