by0ung(at)brigham.net Guest
Posted: Tue May 09, 2006 5:20 am Post subject: Kolb-List Digest: 27 Msgs - 05/07/06 |
Time: 06:13:16 AM PST US
Subject: Re: Minimum pilot weight
Ellery, Thanks for the response. I have done W & B on other planes but I
did not know where the datum point was that was established by Kolb. I got
the window percentages for the Firestar II from another member on the list.
Now I can get busy.
Thanks again
Galen
Galen
It does not matter where the datum is.... but usually kolb uses the leading
edge of the wing,,, it makes for an easier problem to figure the % of wing
cord if figuring cg in % rather than inches from a given point.
Boyd
