Bob H
Posted: Wed Jan 05, 2011 8:10 am Post subject: Pulsar-List Digest: 15 Msgs - 01/04/11 |
Martin;
Just make a sheet by buying some rigid Elast a Foam or Divinylcell, 1/4 "
thick, 3-4 pcf density and laminate a 10 mil glass skin on each side. You
can custom size the sheet for whatever you want.
Regarding Crosswinds-
I did a pure crosswind landing at Valle, AZ once at 17kts reported by
Unicom. Once was enough although plane handled fine. Used wing down
technique and whatever else that kept it on runway.
Bob H
[quote] From: Pulsar-List Digest Server <pulsar-list(at)matronics.com>
Reply-To: <pulsar-list(at)matronics.com>
Date: Tue, 4 Jan 2011 23:57:40 -0800
To: Pulsar-List Digest List <pulsar-list-digest(at)matronics.com>
Subject: Pulsar-List Digest: 15 Msgs - 01/04/11
Today's complete Pulsar-List Digest can also be found in either of the
of the Pulsar-List Digest and can be viewed with a generic text editor
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter=2
011-01-04&Archive=Pulsar
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter
Pulsar-List Digest Archive
Total Messages Posted Tue 01/04/11: 15
Today's Message Index:
1. 03:34 AM - A real request not a test (martin board)
2. 06:53 AM - Re: Cross-Wind Component allowed for Pulsar I
(sonja.englert(at)juno.com)
3. 07:49 AM - Re: test (Bert Reynolds)
4. 08:01 AM - Re: Cross-Wind Component allowed for Pulsar I (Casey King)
5. 08:38 AM - Re: A real request not a test (Lance Goddard)
6. 08:50 AM - Catching up (pilot623)
7. 10:49 AM - Re: A real request not a test (Brian Anderson)
8. 11:50 AM - Test (Coleman)
9. 02:09 PM - Re: Catching up (Casey King)
10. 03:01 PM - Re: Catching up (pilot623)
11. 08:06 PM - Re: Nice to see all the traffic ... even if it is just test
msgs (Ray Thurman)
12. 08:47 PM - Re: Nice to see all the traffic ... even if it is just test
msgs (Jerry Eastman)
13. 10:00 PM - Re: Nice to see all the traffic ... even if it is just test
msgs (Tom Gibbons)
14. 10:06 PM - Re: Catching up (Tom Gibbons)
15. 10:46 PM - Ignor my last (Tom Gibbons)
________________________________ Message 1
_____________________________________
Time: 03:34:40 AM PST US
Subject: A real request not a test
From: martin board <martin.board1950(at)googlemail.com>
Do any of my UK owner/builder friends have any small amounts of composite
sheet I could buy? I have bought a new Jabiru engine for my Pulsar and it is
proving a little difficult to retrofit into my Jabiru bed mount - my old
engine was very early and there are now numerous changes to be made. I need
the composite to build a box behind the firewall to take in a new air intake
system that is yet to be invented! I expect the box will be 4ins wide by
2ins deep and 10 ins long and will be coverered by a similar stainless box
in the firewall itself. I know I can make some composite but with all of the
other changes it is just a job too far.
The engine arrived just before Xmas and I have been worried about all the
changes to be made - largely because of a changed induction system and
larger carb.. The induction system fouls the subframe and the carb is now
very close to the firewall. I have read lots about have tight bends near to
the carb inlet and that is the reason for going back into the plane. It
looks like my carb heat system will have to go in favour of an electic
heater - I think that will simplify some of the plumbing anyhow.
I am taking the plane less wings to the welder on Thursday and I hope I will
not have to cut too much away of the front cowl for access for welding - I
am well away from the bearers so it will be a largely cosmetic issue to sort
out when glassing bits back in. The exhaust header pipes all have to be
modified as Jabiru have changed their design but luckily they have gone for
stainless this time which may mean the current pipes can be mated to the
new.
The most involved issue is removing the firewall, wiring etc etc and in a
cold damp hanger its a bit of a drag. I hope if I do it in small stages with
lots of photos to remind me where everything goes back, everything will
eventually fall into place.
Wish me luck
Martin
________________________________ Message 2
Time: 06:53:30 AM PST US
From: "sonja.englert(at)juno.com" <sonja.englert(at)juno.com>
Subject: Re: Cross-Wind Component allowed for Pulsar I
I would say your speeds are about 10 kts faster than what I usually do, I only
slow it to <60 kts on short final. It can handle 20 kts crosswind, but it
depends
on how gusty or steady it is. If it is real gusty, even less can get you into
trouble.
Sonja
____________________________________________________________
Mortgage Rates Hit 2.99%
If you owe under $729k you probably qualify for Gov't Refi Programs
http://thirdpartyoffers.juno.com/TGL3131/4d23337fbe5ff969e52st05duc
________________________________ Message 3
Time: 07:49:13 AM PST US
Subject: Re: test
got the test. Thanks Bert
On Sun, Jan 2, 2011 at 2:26 PM, Larry Eubanks <leubanks(at)sunflower.com>wrote:
> test
________________________________ Message 4
Time: 08:01:00 AM PST US
The worst crosswind component that I landed in was somewhere in Oklahoma at a
short,
deserted strip. I was in my plane and Doug was in his plane. It was an
adventure
and I'd have to look in my logbook because I put it in there as a special
note. I want to say it was 17 kts. But this was the 90 degree component.
Based on your description, the component was in the 7-14 kt range.
ck
> only
depends
into trouble.
> Sonja
________________________________ Message 5
Time: 08:38:50 AM PST US
Subject: Re: A real request not a test
In case you should want it, a non-European source for composite
materials is ACP in Livermore, CA.
Composite panels, tubes, and rods for a variety of industries
including medical and aerospace: ACP Composites
Good luck, Martin.
Lance Goddard
> composite sheet I could buy? I have bought a new Jabiru engine for
> my Pulsar and it is proving a little difficult to retrofit into my
> Jabiru bed mount - my old engine was very early and there are now
> numerous changes to be made. I need the composite to build a box
> behind the firewall to take in a new air intake system that is yet
> to be invented! I expect the box will be 4ins wide by 2ins deep and
> 10 ins long and will be coverered by a similar stainless box in the
> the other changes it is just a job too far.
> all the changes to be made - largely because of a changed induction
> system and larger carb.. The induction system fouls the subframe and
> the carb is now very close to the firewall. I have read lots about
> have tight bends near to the carb inlet and that is the reason for
> going back into the plane. It looks like my carb heat system will
> have to go in favour of an electic heater - I think that will
> hope I will not have to cut too much away of the front cowl for
> access for welding - I am well away from the bearers so it will be a
> largely cosmetic issue to sort out when glassing bits back in. The
> exhaust header pipes all have to be modified as Jabiru have changed
> their design but luckily they have gone for stainless this time
> which may mean the current pipes can be mated to the new.
> in a cold damp hanger its a bit of a drag. I hope if I do it in
> small stages with lots of photos to remind me where everything goes
> back, everything will eventually fall into place.
> Wish me luck
> Martin
________________________________ Message 6
Time: 08:50:56 AM PST US
Subject: Catching up
Greetings Pulsar People and Happy New Year!
N623JF is still hangared in San Marcos while I search for a job in the
Houston area. Hangar space is hard to find but I think space might soon
become available at Southwest Houston Airport. I've been parking my plane in
a maintenance hangar when it stays with me in Houston (Pearland Municipal)
but the double hangar rent is getting old.
We've done several shorter trips of 90 minutes of less. My mom now lives in
Alice, TX near Corpus Christi so I much prefer flying 90 minutes to driving
4+ hours each way. I now have 60 hours on the new engine.
Bob, that little video on drag makes me want to clean up the gear legs and
finish the inside covers for the wheel pants to get the brake hardware out
of the airstream.
Rhonda and I were married on the beach in Hawaii in late October and life
just keeps on getting better and better.
Happy flying,
Jim & Rhonda Fillman
________________________________ Message 7
Time: 10:49:02 AM PST US
Martin,
I've just made an air intake, and an electric carb heat system for the
Jabiru 220o that is going in my Flitzer. Wondering if these might help.
There are photos on the Jabiru Engines Yahoo group, but maybe you are
not signed in there. The issue of being close to the firewall sounds
similar, so there is not much room for an air intake box. The electric
carb heat system, I'm hoping, will be OK for NZ conditions, especially
for flying an open single seat biplane. UK conditions might require more
attention to carb heat, although it is probably pretty warm under the
Pulsar cowling.
I've attached a couple of photos. Can send more details if you are
interested.
Brian
________________________________ Message 8
Time: 11:50:35 AM PST US
Subject: Test
Just testing the system.- Extra nice to have a new system for me as I hav
e not =0Abeen able to get on the old system for over a year.=0A=0A=0ABill C
oleman=0AN331BP- Pulsar XP=0A=0A=0A________________________________=0AFro
m: Herbert Schmaderer <herbert.schmaderer(at)aon.at>=0ATo: pulsar-list(at)matroni
cs.com=0ASent: Sun, January 2, 2011 9:36:22 AM=0ASubject: test
================== =0A
________________________________ Message 9
Time: 02:09:28 PM PST US
Subject: Re: Catching up
Didn't know you were moving to Houston. Sounds like things are going well.
Is my engine hoist still available or is there a time period when it becomes
yours?
Casey
N623JF is still hangared in San Marcos while I search for a job in the Houston
area. Hangar space is hard to find but I think space might soon become
available
at Southwest Houston Airport. I've been parking my plane in a maintenance
hangar
when it stays with me in Houston (Pearland Municipal) but the double hangar
Alice,
TX near Corpus Christi so I much prefer flying 90 minutes to driving 4+ hours
finish
the inside covers for the wheel pants to get the brake hardware out of the
airstream.
Rhonda and I were married on the beach in Hawaii in late October and life just
Happy flying,
________________________________ Message 10
Time: 03:01:13 PM PST US
Subject: RE: Catching up
Casey,
I've been storing your engine hoist (at no charge ) with the idea that it
would eventually be going home. Here's hoping my need for it has passed
permanently. Let me know when you want it and I'll either deliver it to you
or get you into my hangar if I'm not around.
Jim
| - The Matronics Pulsar-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Pulsar-List |
rwilhelm(at)dc.rr.com Guest
Posted: Wed Jan 05, 2011 9:43 am Post subject: Pulsar-List Digest: 15 Msgs - 01/04/11 |
Happy New Year, Bob.
I bet that missing cover caused a high pressure area under the wing that
added lift and lowered your angle of attack thus reducing drag.
Ray Pulsar III/3300
