elevator control fairlead
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Zenith750-List
dlpier(at)lamar.colostate
PostPosted: Thu Jan 06, 2011 3:36 pm    Post subject: elevator control fairlead Reply with quote
Subject: Elevator control cable fairleads, part# 75C4-5
I mounted mine with a slot cut from the top side, since the cable was
already installed. You are lifting on the cable so there is no danger of
it coming out. I also had to cut a slot in the fuselage skin from the
hole
for the cable in an aft direction in order to give the cable clearance. I
then put a doubler over the area to restore what strength I lost(advised
by
Caleb).
Don Piermattei
N750DP
- The Matronics Zenith750-List Email Forum -
http://www.matronics.com/Navigator?Zenith750-List
Jimmy Young
PostPosted: Fri Jan 07, 2011 10:32 am    Post subject: Re: elevator control fairlead Reply with quote
Thanks for the help.
My upper cable also looks like it's going to be rubbing the aft side of the hole in the top-skin. Will deal with it in a similar manner.
Jimmy Y
Houston TX
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Zenith750-List All times are GMT - 8 Hours
