ph451(at)yahoo.com Guest
Posted: Sat Jan 01, 2011 6:04 pm Post subject: In defense of CJs |
[quote][b] [quote][b]
wdjester(at)cox.net Guest
Posted: Sun Jan 02, 2011 5:01 am Post subject: In defense of CJs |
gheez, how about a little poetic license...
cjpilot710(at)aol.com Guest
Posted: Sun Jan 02, 2011 5:35 am Post subject: In defense of CJs |
Oh No Goatboy. You've crossed a line here. I've yet seen a Yak out run a CJ. You don't fight to the other guy's strength. You kill with your own. AC101 "Boots"
Pappy
Posted: Mon Jan 03, 2011 1:36 pm Post subject: In defense of CJs |
Well of course as a YAK-50 owner, I have to weigh in here. It is not
really accurate for folks to use the term "Yak" in a general sort of
way. There is a ton of difference in the performance between the YAK-52
(all models), the YAK-50, the YAK-54 and the YAK-55.
What is Vne on the CJ ??? Is it above about 285 MPH? I don't think
so. So, yes.... the YAK-50 can outrun the CJ in a dive. Kind of like
the P-47 Thunderbolt. It could run away from just about anything in a
dive. The YAK-50 can easily out dive the CJ.
What is maximum level speed at full throttle of the CJ-6 ?? The YAK-50
claims 200 mph straight and level. Personally, I have never seen that.
On a perfect day, I have achieved a measured 197 mph WFO, and that means
intentionally exceeding the maximum full power output time limitations.
That's with the 360 HP M-14P and a stock Russian paddle blade prop.
The YAK-50 has a better thrust to weight ratio and can indeed fight in
the vertical far better than the CJ. It also has a higher roll rate,
and higher G limitations, although it is not very smart to run it up to
9 G's anymore.
Of course there is always the matter of pilot skills, and his or her
knowledge of tactics, and I agree with Pappy 100%. You don't fight to
the other guy's strengths! ABSOLUTELY CORRECT.
For what it is worth, I do indeed tend to go vertical with any opponent
when I know my vertical penetration is going to greatly exceed that of
my opponent. As far as it working only in a canned setup with a
cooperating bogey, I would go back to actual accounts of WW-II with the
written stories of actual fighter pilots going against Jap Zero's. This
tactic was used very effectively against American pilots in the
beginning of the war and accounted for a lot of lost American aircraft,
until our aircraft improved enough to where the roles were reversed. We
initially countered their aircraft handling superiority with "tactics"
designed to force them into fighting to our strengths, just like Pappy
said.
Any Yak can be defeated by any CJ, given the right circumstances.
However, the performance of the YAK-50 in a dogfight is vastly superior
to the CJ-6. This is not a matter of pride of ownership (well, OK...
maybe a little) but really is a simple matter of just looking at the
numbers.
The YAK-50 has a higher rate of climb, a higher thrust to weight ratio,
better vertical penetration, better roll rate, and higher G limitations.
It is a purpose built aerobatic aircraft. The CJ does not have any of
these strengths. All that said, put the right guy into the CJ and he
will probably beat the YAK-50 every time. But given equal pilot skill
and knowledge levels, I don't honestly see how a CJ-6 could ever beat a
YAK-50.
Mark Bitterlich
N642K
richard.goode(at)russiana Guest
Posted: Tue Jan 04, 2011 8:51 am Post subject: In defense of CJs |
Mark-you need long range wing-tanks in the 50!!!
Richard Goode Aerobatics
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
United Kingdom
Tel: +44 (0) 1544 340120
Fax: +44 (0) 1544 340129
www.russianaeros.com
I'm currently in Sri Lanka but this Mail is working,and my local phone is
+94 779 132 160.
Posted: Tue Jan 04, 2011 10:36 am Post subject: In defense of CJs |
Richard, I now also have a UTVA-66.
I have also realized I can't afford two airplanes. But I can't stand to
part with either!
So.... long range tanks, new paint job, M-14PF mod, MT9-260 prop...
etc., are kind of out of reach. Big sigh.
Mark
barryhancock
Posted: Fri Jan 07, 2011 9:23 am Post subject: Re: In defense of CJs |
Just to take what Mark was saying about the -50 a step further. The Yak-50 is the absolute, unequivocal king of the hill for piston aircraft in BFM (did I just use that acronym out loud?!?). Planes like the Extra, Marchetti SF260, Panzel, I-3/E-3, etc. have all tried, and walked away with new found respect for the -50.
Pappy, the only way a CJ stands a chance in a neutral fight with a -50 is limiting the -50 to below 70% power, gear out, and one mag off... -
Happy fighting, err, flying!
Barry
_________________ Barry Hancock
Worldwide Warbirds, Inc.
www.worldwidewarbirds.com |
kingcj6(at)aol.com Guest
Posted: Fri Jan 07, 2011 10:02 am Post subject: In defense of CJs |
Barry - I suspect a backseater wiith a .45 Thompson in a CJ would even the odds...but wait, a -50 doesn't have a back seat!
Dave
Quote: | Quote: | Pappy, the only way a CJ stands a chance in a neutral fight with a -50 is
Barry |
rick(at)rvairshows.com Guest
Posted: Fri Jan 07, 2011 10:03 am Post subject: In defense of CJs |
I wonder what the Yak 50 could do against a range of even higher performance aircraft than you have mentioned , such as a SU 26 or MXS or even an Edge 540. Any one have any experience with these three?
Rick Volker
barryhancock
Posted: Fri Jan 07, 2011 10:48 am Post subject: Re: In defense of CJs |
Hi Rick,
Yes, Su26, Panzel, etc., the symmetrical airfoil of modern aerobatic aircraft bleeds energy much faster than the -50 wing. The result is a higher sustained G for the -50, a higher potential energy state, recovers energy much quicker, etc. Initial turn rate for the modern aircraft is probably higher, but that advantage is quickly lost to a lower energy state. This is why the modern aerobatic aircraft are well, aerobatic aircraft and the -50 is the most highly coveted dogfighter around....
Happy aggressive cooperative aerobatics,
Barry
Posted: Fri Jan 07, 2011 3:20 pm Post subject: In defense of CJs |
You still have to fly it.
--- On Fri, 1/7/11, barryhancock <bhancock(at)worldwidewarbirds.com> wrote:
Quote: |
From: barryhancock <bhancock(at)worldwidewarbirds.com>
Subject: Re: In defense of CJs
To: yak-list(at)matronics.com
Date: Friday, January 7, 2011, 6:48 PM
--> Yak-List message posted by: "barryhancock" <bhancock(at)worldwidewarbirds.com (bhancock(at)worldwidewarbirds.com)>
Hi Rick,
Barry
Barry Hancock
(909) 606-4444
http://forums.matronics.com/viewtopic.phpwww.matronics.com/Navigator?Yak-List" target=_blank>http://www.matronics.========================http://forums.msp; - List Contribution Web Sbsp; > http
barryhancock
Posted: Fri Jan 07, 2011 5:23 pm Post subject: Re: In defense of CJs |
Umm.....ready left.
You are right, the drawing board is of little consequence when the fight is on....but my real world observation and experience is that the -50 is without peer and will make even an average guy an above average threat against anything other than another -50.
I'm done...
Posted: Fri Jan 07, 2011 5:41 pm Post subject: In defense of CJs |
Yep. 120 Klicks in the vertical un loaded on it's back turning inside it's ass. Thrust vectoring eat your heart out. Now, that's nose authority.
Doc
Sent from my iPad
On Jan 7, 2011, at 5:16 PM, Paul Hamlin <ph451(at)yahoo.com (ph451(at)yahoo.com)> wrote:
[quote]You still have to fly it.
--- On Fri, 1/7/11, barryhancock <bhancock(at)worldwidewarbirds.com (bhancock(at)worldwidewarbirds.com)> wrote:
Quote: |
From: barryhancock <bhancock(at)worldwidewarbirds.com (bhancock(at)worldwidewarbirds.com)>
To: [url=mailto:yak-list(at)matronics.com]yak-list(at)matronics.com (yak-list(at)matronics.com)[/url]
--> Yak-List message posted by: "barryhancock" <[url=mailto:bhancock(at)worldwidewarbirds.com]bhancock(at)worldwidewarbirds.com (bhancock(at)worldwidewarbirds.com)[/url]>
Hi Rick,
Barry
Barry Hancock
(909) 606-4444
[/url] | [url=http://www.matronics.com/contribution]
