		quinn_tom(at)tqiinc.com Guest
				 Posted: Mon Jan 10, 2011 4:25 pm    Post subject: Wow, what a difference! |
				Just got my plane back from annual with a Sensenich prop replacing the stock
 McCauley prop on my 1977 Tiger, now the airplane climbs like a bat out of
 hell (over 1500 fpm on -300 alt press day) and I saw 132 knots GS at 2,000
 (2,650 rpm) feet on a calm day. Can't wait to get it to altitude. Wish I had
 done this much earlier.
 Tom Quinn 249RR
  |  | - The Matronics TeamGrumman-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		teamgrumman(at)yahoo.com Guest
				 Posted: Mon Jan 10, 2011 10:09 pm    Post subject: Wow, what a difference! |
				What pitch did you get?
 On Jan 10, 2011, at 4:17 PM, "Tom Quinn" <quinn_tom(at)tqiinc.com> wrote:
  Tom Quinn 249RR
				 Posted: Tue Jan 11, 2011 2:13 am    Post subject: Wow, what a difference! |
				62" pitch
 Tom Quinn
 249RR
		flyv35b(at)minetfiber.com Guest
				 Posted: Tue Jan 11, 2011 5:24 am    Post subject: Wow, what a difference! |
				That's what Fletchair recommends most of the time.  But it's not enough
 pitch for a clean airframe and a strong engine, especially if you put a PF
 exhaust on it.
 Cliff
				 Posted: Tue Jan 11, 2011 6:04 am    Post subject: Wow, what a difference! |
				Cliff,
         I spoke with Garner before buying the prop and I didn't have plans
 of buying the PF system in the near future. If I hang onto the airplane for
 a while I may install the PF system and I'm guessing the prop can be
 re-pitched? I'm still amazed how much of a difference the new prop makes.
 Not only is the performance so much better but the engine runs much
 smoother, I can see why there was an RPM limitation on the McCauley prop. My
 wife is avoiding me now because I keep on telling her how great the
 performance is every time I see her.
 Tom Quinn
 249RR
				 Posted: Tue Jan 11, 2011 6:25 am    Post subject: Wow, what a difference! |
				Yes, you can repitch the prop.  And you may want to do that if you
 eventually install the PF exhaust as it will add about 80 rpm to your full
 throttle engine rpm.  If that turns out to be 2900 rpm or thereabouts then
 you might want more pitch.  You have to do some testing to determine where
 you are though.
 And yes, the McCauley does have a resonant vibration in the yellow arc area
 that is greater than with the Sensenich.
 Cliff
				 Posted: Tue Jan 11, 2011 6:39 am    Post subject: Wow, what a difference! |
				I might also add that full throttle rpm decreases with altitude, probably
 about 100 rpm from sea level to 10,000 ft.  So if you can turn 2800 rpm down
 low then at 10,000 ft or higher you will max out at about 2700 rpm, which
 will be optimum for maximum legal cruise speed.
 Cliff
		bob.hodo(at)yahoo.com Guest
				 Posted: Tue Jan 11, 2011 6:46 am    Post subject: Wow, what a difference! |
				 	  | Quote: | 	 		  >>My wife is avoiding me now because I keep on telling her how great the
  performance is every time I see her.<<<
  I know what you mean! You can tell us, 'cause we know exactly how great that feels.
  Bob Hodo
  GADsden, AL
				 Posted: Tue Jan 11, 2011 11:09 am    Post subject: Wow, what a difference! |
				the rpm range where the restriction was on the McCauley prop is still a range to be cautious of with the Sensenich.  The Sensenich prop is not as susceptible to the harmonics at that rpm, but the problem is still there.
 Sent: Tue, January 11, 2011 6:01:05 AM
 Subject: RE: Wow, what a difference!
   --> TeamGrumman-List message posted by: "Tom Quinn" <quinn_tom(at)tqiinc.com (quinn_tom(at)tqiinc.com)>
 Cliff,
 Tom Quinn
 249RR
				 Posted: Tue Jan 11, 2011 11:11 am    Post subject: Wow, what a difference! |
				the Power Flow on my plane gave me 80 rpm at 17,000 feet.  I was still turning 2675.
 Sent: Tue, January 11, 2011 6:19:52 AM
 Subject: Re: Wow, what a difference!
  --> TeamGrumman-List message posted by: "flyv35b" <flyv35b(at)minetfiber.com (flyv35b(at)minetfiber.com)>
 you are though.
 Cliff
				 Posted: Tue Jan 11, 2011 11:41 am    Post subject: Wow, what a difference! |
				That highest I’ve had my Tiger is 10,000, I could have gone higher I guess at about 200fpm (summer time). What was the highest altitude you were capable of before installing the PF system?
 Tom Quinn
 249RR
 From: owner-teamgrumman-list-server(at)matronics.com [mailto:owner-teamgrumman-list-server(at)matronics.com] On Behalf Of Gary Vogt
  Sent: Tuesday, January 11, 2011 2:09 PM
  you are though.
  Cliff
		rdp123(at)verizon.net Guest
				 Posted: Tue Jan 11, 2011 3:46 pm    Post subject: Wow, what a difference! |
				Tom, I flew my stock Tiger to 18,000ft with half fuel and one passenger when i was testing a portable oxygen system. I was still climbing at about 125 f/m but legally could not go higher into class A airspace  -  The controls were mushy as hell and the plane was going pretty slow.
 Rick
 On Jan 11, 2011, at 11:31 AM, Tom Quinn wrote:
 [quote]That highest I’ve had my Tiger is 10,000, I could have gone higher I guess at about 200fpm (summer time). What was the highest altitude you were capable of before installing the PF system?
 Tom Quinn
 249RR
 From: owner-teamgrumman-list-server(at)matronics.com (owner-teamgrumman-list-server(at)matronics.com) [mailto:owner-teamgrumman-list-server(at)matronics.com] On Behalf Of Gary Vogt
 To: teamgrumman-list(at)matronics.com (teamgrumman-list(at)matronics.com)
 From: flyv35b <flyv35b(at)minetfiber.com (flyv35b(at)minetfiber.com)>
 you are though.
 Cliff
