rleffler
Posted: Mon Jan 10, 2011 12:06 pm Post subject: Prop Governor revisited |
I'm sitting on that fence at the moment too. While I believe the pcu5000 to be the better unit, I'm not sure the cost difference justifies the expense.
On Jan 10, 2011, at 10:46 AM, Kelly McMullen <apilot2(at)gmail.com (apilot2(at)gmail.com)> wrote:
[quote]>From an old thread. One other message in the thread indicated that Rev F and up governor governors would work fine. I'm kind of on the fence between ordering the correct MT from source other than Vans, or ordering a PCU5000.
---------- Forwarded message ----------
From: <[url=mailto:lessdragprod(at)aol.com]lessdragprod(at)aol.com (lessdragprod(at)aol.com)[/url]>
Date: Sat, Aug 14, 2010 at 3:45 AM
Subject: Re: Prop Governor revisited
To: [url=mailto:rv10-list(at)matronics.com]rv10-list(at)matronics.com (rv10-list(at)matronics.com)[/url]
I believe the question being asked is "Is only getting 2550 RPM maximum acceptable when a (I)O-540 narrow deck governor is installed on a (I)O-540 wide deck engine".
I wouldn't think so.
Especially when Van's Aircraft could provide the correct governor. I am aware of them knowing about this for at least three years.
Just my opinion.
Jim Ayers
RV-3 sn 10050 650 hours - LOM M332A engine - 3 blade electric CS MT Propeller & Warne fixed pitch propeller
RV-6A sn 21873 150 hours - Lyc. O-360 engine - metal 2 blade CS MT Propeller & 3 blade CS MT Propeller
RV-4/HR2/modified sn 001 28 hiours - IO-540 narrow deck engine - counterweighted 4 blade CS MT Propeller & counterweighted 3 blade CS Propeller in process.
_________________ Bob Leffler
N410BL - Phase I
jcumins(at)jcis.net Guest
Posted: Mon Jan 10, 2011 12:26 pm Post subject: Prop Governor revisited |
I have talked to American Propeller about this and they claim the PCU is much better governor. The cost savings will be a repair or overhaul time. They claim the MT will be shot and almost not rebuild able, vs the PCu will be a very easy overhaul.
I am thing of using a PCU and Whirlwind 3 Blade prop combo. I talked to the Engineer who designed the 3 blade Whirlwind prop and very much like the design and thing it will outperform the MT. I am not a fan of wod/glassed props that MT makes.
Just my 2 cents worth.
40864 Emp complete Primered ribs the weekend. The fun continues.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Leffler
Sent: Monday, January 10, 2011 12:04 PM
| Quote: | From an old thread. One other message in the thread indicated that Rev F and up governor governors would work fine. I'm kind of on the fence between ordering the correct MT from source other than Vans, or ordering a PCU5000.
From: <lessdragprod(at)aol.com (lessdragprod(at)aol.com)>
Just my opinion.
Jim Ayers
philperry9(at)gmail.com Guest
Posted: Mon Jan 10, 2011 12:39 pm Post subject: Prop Governor revisited |
How long is the service life of a prop gov and what type of maintenance is involved?
Phil
Posted: Mon Jan 10, 2011 12:52 pm Post subject: Prop Governor revisited |
I received the same feedback on the governor from my engine builder.
The prop was still in development and “in testing” when I made the choice, if I recall the only prop more expensive at the time was the aerocomposite, and the Carbon Lycoming. In the end it was the standard 2 blade for me. half the price to boot!
Sent: Monday, January 10, 2011 12:16 PM
Subject: RE: Prop Governor revisited
Just my opinion.
Jim Ayers
-----Original Message-----
From: Condrey, Bob (US SSA) <bob.condrey(at)baesystems.com (bob.condrey(at)baesystems.com)>
To: rv10-list(at)matronics.com (rv10-list(at)matronics.com) <rv10-list(at)matronics.com (rv10-list(at)matronics.com)>
Sent: Fri, Aug 13, 2010 9:22 am
| Quote: | | --> RV10-List message posted by: "Condrey, Bob (US SSA)" <bob.condrey(at)baesystems.com (bob.condrey(at)baesystems.com)> As long as you have at least Rev F of the governor supplied by Vans you'll be fine. Revisions prior to that potentially have an issue with surging. I would imagine that anything you get delivered now will be latest revision. If others are reading this and they have an older Rev B or C prop governor, MT will update it to latest version without charge if you have issues. Bob--> RV10-List message posted by: "Condrey, Bob (US SSA)" <bob.condrey(at)baesystems.com (bob.condrey(at)baesystems.com)> | 01[quote]--
rv10flyer
Posted: Mon Jan 10, 2011 7:34 pm Post subject: Re: Prop Governor revisited |
Phil,
My MT gov P-860-3 specs sheet says 6 yrs or 2000 hrs whichever comes first. No idea if it will make it or not. Only time will tell.
_________________ Wayne G. |
Strasnuts
Joined: 10 Feb 2009 Posts: 502 Location: Salt Lake City, UT
Posted: Tue Jan 11, 2011 4:32 am Post subject: Re: Prop Governor revisited |
I have a wide deck IO-540-N1A5. After Kelly posted the gear ratio reminder I was worried about my governor I received from Vans. I have the -3 model for narrow deck so I called MT. The tech advised me that it will probably work as is. If it doesn't reach full RPM there are options. First try to adjust the set screw that is safety wired by rotating it out. If that still doesn't work I call him back and he talks me through internally adjusting the governor. Either way I won't have to send it back to MT. This is also because I have the latest mod on the governor.
_________________ 40936
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours |
