kearney
Posted: Fri Jan 14, 2011 7:26 pm Post subject: TT Pitch Servo Install Directions |
Hi
Today I mounted my TT servo. After studying the detailed install pix, I did
a search of the archives to find out where to drill the bell crank. I found
Jay's email which has a small but critical typo.
When I marked the location indicated, it didn't seem to match the location
shown in the install pix. I confirmed with TT that the bell crank hole
should be 2.5" up from the center hole and .25" aft of a line drawn beween
the center hole and top hole. The result is consistent with the pix.
I only mention this as the TT install docs are abysmal. The other prior
posts (circa 2007) were very useful. I would be lost without this list...
Cheers
Les
rv10flyer
Posted: Fri Jan 14, 2011 8:45 pm Post subject: Re: TT Pitch Servo Install Directions |
I would recommend installing .063" spacer in bellcrank where your hole is drilled. Otherwise you cannot torque bolt without deforming the bellcrank. I bet there is a bunch out there without this installed.
During your annual inspection keep an eye on the cable around the phenolic pulley(torque enhancer). If it breaks it could limit up elevator travel as it jams against mounting bracket.
_________________ Wayne G. |
