samhord2(at)gmail.com Guest
Posted: Wed Jan 12, 2011 7:56 am Post subject: Rotax (912-914) prop hub |
Could someone give me the dimensions of the center flange on the prop hub of a 912-914. My prop extension is for a sae1 and there aren't to many prop options. Seems like Rotax has cornered the market. The bolt pattern is 4"x3/8", but I can't find the center dimension.
Sam Hord n ID 701
stepinwolf
Posted: Wed Jan 12, 2011 8:07 am Post subject: Rotax (912-914) prop hub |
Sam,
As close as I can measure, the center flange on my 912 work's out to 1 7/8".
Hope this helps.
Robert
the 701&750 scratch
_________________ Long wing + vga's, = lo & slo |
bobkat
Joined: 07 Sep 2008 Posts: 143 Location: Bismarck, ND
Posted: Wed Jan 12, 2011 9:09 am Post subject: Rotax (912-914) prop hub |
Be careful because the older 912's have a slightly different bolt pattern than the more recent ones. My older 80 hp on my Kit fox was different than my newer 100 Hp 912. Check the serial numbers - they are a bit difficult to measure.
From: Robert Pelland (robert.pelland(at)cgocable.ca)
Sent: Wednesday, January 12, 2011 10:01 AM
To: zenith701801-list(at)matronics.com (zenith701801-list(at)matronics.com)
Subject: Re: Rotax (912-914) prop hub
Sam,
Hope this helps.
Robert
the 701&750 scratch
