paul.r.kuntz(at)gmail.com Guest
Posted: Fri Jan 21, 2011 11:01 am Post subject: D-sub crimper |
I have a supply of gold-plated D-sub pins and a ratchet crimper -- both pins and crimper were purchased from B&C. I will be using 20 ga and 22 ga wiring in my aircraft, but note that there is no adjustment on the crimper for different wire gauges. I saw in an EAA informational video the use of a D-sub crimper that had an adjustment to adapt it to different wire gauges. Do I need one of these adjustable crimpers? If I use the one from B&C and give each pin a pull test after crimping, is that good enough?
Paul Kuntz
Posted: Fri Jan 21, 2011 8:34 pm Post subject: D-sub crimper |
At 01:57 PM 1/21/2011, you wrote:
| Quote: | I have a supply of gold-plated D-sub pins and a ratchet crimper --
The B&C crimper (mfg by Eclipse) has been
on the market now for 10 years that I know
of. It has performed well with 20 and 22AWG
wire in d-sub pins.
Posted: Fri Jan 21, 2011 10:03 pm Post subject: D-sub crimper |
Thanks for your always prompt and useful information, Bob.
Paul Kuntz
On Fri, Jan 21, 2011 at 7:30 PM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
[quote]--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
| Quote: | I have a supply of gold-plated D-sub pins and a ratchet crimper -- both pins and crimper were purchased from B&C. I will be using 20 ga and 22 ga wiring in my aircraft, but note that there is no adjustment on the crimper for different wire gauges. I saw in an EAA informational video the use of a D-sub crimper that had an adjustment to adapt it to different wire gauges. Do I need one of these adjustable crimpers? If I use the one from B&C and give each pin a pull test after crimping, is that good enough?
wire in d-sub pins.
-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
http://forums.matronics.com
le, List Admin.
