drfred(at)suddenlinkmail. Guest
Posted: Mon Jan 24, 2011 2:09 pm Post subject: Step |
I wanted to add another data point to the broken step. I took some
friends up for a ride this weekend. As a 300 lb guy was getting into
the plane, the right step broke off . Same place as previous notes.
Weld broke, looked like minimal weld material at top. I had a
significant amount of rust inside. I remember that I did put some
primer inside the tube. Will have to cut access holes to get to the bolt.
May be something to think about if you have a heavy person to get in the
plane. Might want to get a small step stool out to help them get up a
little higher. When he was getting in the plane, he couldn't quite get
his weight forward enough to grab the door sill. So he kinda hesitated
and tried to catch his balance and wavered on the step just before it
broke. Maybe if he had a step it would have been a little easier and he
wouldn't have stressed the weld so much.
Of course, small dent in the skin underneath.
I'll try and take some pics and post later. May be the weekend before I
can address the issue.
Dr Fred
515 FW.
davidsoutpost(at)comcast. Guest
Posted: Mon Jan 24, 2011 3:43 pm Post subject: Step |
One of my steps had a stress crack about 3/8" long on the top of the step weld where it joins the strut. There was a small pit where it started in the middle. I have a TIG welder so I re-welded both steps adding quite a bit of filler as I went along. No way I want to have to remove one if/when one breaks, and that particular step would have broke real quickly. I am now waiting them to come back from chroming so I can get them installed and install the baggage floors.
David Clifford
RV-10 Builder
N849RV (reserved)
Posted: Mon Jan 24, 2011 3:51 pm Post subject: Step |
Sounds like 300lbs is the limit on the step. Regardless of the rust I think
there needs to be a concern that the step is a sore spot on the planes.
While up at a VAF Socal meeting and show and tell there was a RV-7 that had
a missing step as well. Seems many have commented on the weak weld and need
to reweld the step before it breaks.
I am seriously thinking of a portable step for my passengers. It may be a
hassle, for the few times I do it, but it will be better than a broken step
that will force me to do more later.
Pascal
rv10rob(at)gmail.com Guest
Posted: Mon Jan 24, 2011 4:24 pm Post subject: Step |
Are people getting injured when these things break?
-Rob
On Mon, Jan 24, 2011 at 3:48 PM, Pascal <rv10builder(at)verizon.net (rv10builder(at)verizon.net)> wrote:
[quote]--> RV10-List message posted by: "Pascal" <rv10builder(at)verizon.net (rv10builder(at)verizon.net)>
Sounds like 300lbs is the limit on the step. Regardless of the rust I think there needs to be a concern that the step is a sore spot on the planes. While up at a VAF Socal meeting and show and tell there was a RV-7 that had a missing step as well. Seems many have commented on the weak weld and need to reweld the step before it breaks.
I am seriously thinking of a portable step for my passengers. It may be a hassle, for the few times I do it, but it will be better than a broken step that will force me to do more later.
Pascal
Kelly McMullen
Posted: Mon Jan 24, 2011 4:34 pm Post subject: Step |
Has anyone considered putting a grab handle under the right rear
window to help passengers come aboard?
On Mon, Jan 24, 2011 at 4:48 PM, Pascal <rv10builder(at)verizon.net> wrote:
Pascal
A&P/IA, EAA Tech Counselor
KCHD |
Tim Olson
Posted: Mon Jan 24, 2011 4:51 pm Post subject: Step |
Step breakage issues aren't unique to RV's...they're common on
many other models too. So they're always something to treat
carefully. A portable step would be a good idea if you're
loading a lot of chubbies....you not only have the step breakage
issue but if you're aft loaded with gear, you could have the
"smash the tail to the ground" issue too.
Tim Olson - RV-10 N104CD
Pascal
jcumins(at)jcis.net Guest
Posted: Mon Jan 24, 2011 5:25 pm Post subject: Step |
We have a handle mounted on the curve of the fuselage above the step on our
Saratoga, and I plan on adding 2 ea type handles to my -10 one on each side
makes climbing the step much easier and safer.
John G. Cumins
40864 Wings Rib riveting
dmaib(at)mac.com Guest
Posted: Mon Jan 24, 2011 5:43 pm Post subject: Step |
I put handles above the rear windows, and many others have as well.
They are similar to handles on the older Bonanza I used to fly, and
they work well.
David Maib
40559
flying
On Jan 24, 2011, at 7:29 PM, Kelly McMullen wrote:
> rust I think
> planes.
> that had
> and need
> may be a
> broken step
> Pascal
taildragon(at)msn.com Guest
Posted: Mon Jan 24, 2011 6:05 pm Post subject: Step |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]-->
Is there an upper limit on the size of a single passenger or pilot? It seems that there would be a limit to how much can walk on the wing or that the seat and seat belts can support during CAT or high G maneuvers.
Roger
> On Mon, Jan 24, 2011 at 4:48 PM, Pascal <rv10builder(at)verizon.net (rv10builder(at)verizon.net)>
> rust I think
> planes.
> that had
> and need
> may be a
> broken step
> Pascal
Posted: Tue Jan 25, 2011 6:42 am Post subject: Step |
David ;
Do you know if the step material is 4130?Â
And to answer the other question, the guy didn't injure himself. Just dropped straight down. Didn't hit the flap edge. He never got up that far. I was thinking about the tipping issue when he climbed in.Â
Dr Fred
515FW
On 1/24/2011 5:40 PM, davidsoutpost(at)comcast.net (davidsoutpost(at)comcast.net) wrote: [quote] p { margin: 0; } One of my steps had a stress crack about 3/8" long on the top of the step weld where it joins the strut. There was a small pit where it started in the middle. I have a TIG welder so I re-welded both steps adding quite a bit of filler as I went along. No way I want to have to remove one if/when one breaks, and that particular step would have broke real quickly. I am now waiting them to come back from chroming so I can get them installed and install the baggage floors.
David Clifford
RV-10 Builder
N849RV (reserved)
tsts4
Posted: Tue Jan 25, 2011 7:42 am Post subject: Re: Step |
David,
(Sorry for the thread high-jack everyone), would you mind posting some more details on the handle (where to buy, how you installed, etc)?
Todd
_________________ Todd Stovall
aka "Auburntsts" on EAA and VAF
RV-10 N728TT -- Flying |
bruce1hwjohnson(at)yahoo. Guest
Posted: Tue Jan 25, 2011 10:23 am Post subject: Step |
Do you have any pics too post on those handles?
Sent: Mon, January 24, 2011 6:40:41 PM
Subject: Re: RV10-List: Step
--> RV10-List message posted by: David Maib <dmaib(at)mac.com (dmaib(at)mac.com)>
I put handles above the rear windows, and many others have as well. They are similar to handles on the older Bonanza I used to fly, and they work well.
David Maib
40559
flying
| Quote: | --> RV10-List message posted by: Kelly McMullen <apilot2(at)gmail.com (apilot2(at)gmail.com)>
On Mon, Jan 24, 2011 at 4:48 PM, Pascal <rv10builder(at)verizon.net (rv10builder(at)verizon.net)> wrote:
> Pascal
; bsp; -Matt Dralle, List Admin.
