Comm Antenna & SWR Reading: Additional Info
bobair(at)me.com
PostPosted: Mon Jan 24, 2011 12:50 pm    Post subject: Comm Antenna & SWR Reading: Additional Info Reply with quote
Bob, et al,
Here is some additional information:
To Bob's inquiry "It would be interesting to do an ohmmeter test from center pin on the antenna's connector and ground. If is shows a 'short', I suspect that some sort of matching system is installed.", my ohmmeter showed a complete open between the center pin and the shell of the BNC connector on the antenna base.
To Dj Merrill's questions:
1. The antenna base is about 16" aft of the aft portion of the GlaStar's metal cage steel tubing and about 54" aft of the main gear legs (my 'Star is a taildragger). The bent whip portion of the antenna trails aft, obviously, from the base. We didn't check the SWR while moving the empennage control cables -- they run about 3" - 4" above the antenna base. (But I just installed in the tail cone about 18" above the control cables a magnetometer for a Dynon EFIS and the indicated heading didn't change when I moved the elevator controls if that info is relevant to this discussion.)
2. The antenna base is installed on the exterior surface of the composite fuselage and the ground plane is on the inside surface. They are about 7/16" of an inch apart and, as I mentioned before, electrically bonded by the four stainless machine screws that mount the antenna to the airplane. I haven't researched whether the antenna must be mounted directly on the ground plane -- if so, that will be an issue since some composite surgery will be required that I'd really rather avoid.
3. I didn't see any adjustment on the antenna itself.
Based on the responses, it looks like I've got some more tweaking/testing to do. Specifically:
Re-test the antennas (including the cat's whisker) and their feed lines separately, and then together after I've got the feed lines cut to final length and with their final BNC connectors in place. The RG-400 feed line from the Comm 1 antenna to the Garmin 430W will be about 10' long. I can vary (i.e., lengthen) that length if it will help performance. Is there a rule of thumb in how long to make antenna feed lines for optimum performance?
When re-running the tests, would it make any difference to use a more powerful transmitter than my little hand-held? Or should I stick with what I used originally to eliminate one more variable that might affect the follow-on data?
Thanks for the helpful advice.
Best regards,
Bob
deej(at)deej.net
PostPosted: Mon Jan 24, 2011 1:15 pm    Post subject: Comm Antenna & SWR Reading: Additional Info Reply with quote
Typically the longer the cable run, the higher the loss induced by the
cable, so I strive to make the cable runs as short as practical while
still leaving adequate length for maintenance, moving things, etc. An
extra foot or two won't make much difference, but I wouldn't leave an
extra ten feet, for example.
I typically test with a 5 watt handheld. I can see no reason to throw
more power at it. However, it might be worth trying the test with a
different handheld to remove the radio itself as a potential source of
the problem.
-Dj
Dj Merrill - N1JOV
Glastar Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/
Please use Netiquette Guidelines http://tools.ietf.org/html/rfc1855
Kindly TRIM your email replies and post AFTER the relevant text
Float Flyr
PostPosted: Tue Jan 25, 2011 10:02 am    Post subject: Comm Antenna & SWR Reading: Additional Info Reply with quote
Another problem with making the feed line much too long is what to do with
the access. If you coil it up you have just made another electrical tuning
circuit. This can be really bad with unshielded zip wire like used in some
stereo systems.
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
