Tyre Tube Types
peter.rees01(at)tiscali.c
PostPosted: Sun Jan 30, 2011 1:44 pm    Post subject: Tyre Tube Types Reply with quote
We have been suffering with a few flat tyres recenly - guess its time to change the tubes on HI
I know that the size for the Tri are 5.00x5 but I don't know if the valve is straight or rightangled - can anyone assist?
Tyres came from Watts - is this the best place to get tubes from - any recommendations welcome
Peter
ptag.dev(at)tiscali.co.uk
PostPosted: Mon Jan 31, 2011 3:40 am    Post subject: Tyre Tube Types Reply with quote
The Tubes you require are right angled. I have stuck with Watts but had issues with the nose wheel tube since it was slightly too large causing a fold when inflated in the tyre. Best to be slightly undersize because tubes will expand but creases cause punctures.
|||||||||||Bob \Harrison G-PTAG
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Peter Rees
Sent: 30 January 2011 21:41
Subject: Tyre Tube Types
Peter
